Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Πολύ ενδιαφέρουσα εταιρία από τις ΗΠΑ με σχετικά χαμηλές τιμές!!! Δεν έχει μεγάλη γκάμα προϊόντων, αλλα σίγουρα όλα είναι εντυπωσιακά!!!
Προενισχυτής P10
TECHNICAL SPECIFICATIONS
Inputs: 4 x Line RCA, 1 x XLR, 1x Phono, selective gain MM or MC + subsonic filter, Phono: custom impedance load option R/C-selective
Frequency Response: 20Hz-22kHz , 0 dB – 0.05dB
Distortion IMD: max 0.003% (60 Hz/4 - 20kHz, 4:1)
Distortion THD+N (BW 80kHz): max 0.005% 20Hz –22kHz for output 8Vrms typical 0.002% / 1V
Channel Separation: -105dB, 20Hz-22kHz
Noise S/N: 110dB for link inputs (20Hz /22kHz), 90dB/MM, 85dB/MC (IHF A)
Channel Matching: < 0.05dB 0dB -60dB
Max Input Voltage: 8Vrms
Output Impedance: 50 ohm XLR, 220 ohm RCA, 220ohm REC
Outputs: 1 x REC output, (tape output) 1 x output XLR 1 x output RCA
Input Sensitivity: 0.6V for link inputs 2-5
Connectors: signal inputs and outputs – RCA, XLR, gold plated
Volume Control: Microprocessor Driven DACs, -112dB to 0dB in 0.5dB step
Dimensions/Weight: 17 ½ x 1 ¾ x 13 inch, net weight 4.5 lb
ST-BY Power Consumption: 2VA
AC line voltage: 110-120 ACV, 60 Hz, 5.5VA
τιμή: $1790
Τελικός ενισχυτής PA300
Power Output: 2x120W RMS 8ohm
2x200W RMS 4ohm
Frequency Response: 20Hz-22kHz /0 dB – 0.1dB 3.3Hz and 190kHz / -1dB, 1.2Hz and 450kHz / -3dBdB
Slew Rate: 50V / us /8ohm
Damping Factor: 500/1kHz/8ohm, 380/10kHz/ 8ohm
Noise S/N: -105 dB (20Hz-22kHz)
Distortion IMD: max 0.002% for 100W/8ohm (60 Hz/4 – 80kHz, 4:1)
Distortion THD+N 0.001% /120W/8ohm
0.0018% /200W/4ohm,
Outputs: LINK OUT XLR gold plated, bi-amping optional
Inputs: XLR gold plated
Channel Separation: -105 dB, 20Hz-22kHz
DC Offset: max 10mV, typical <5mV
Dimensions/Weight: 17 ½ x 3 ½ x 14 ¼ inch, net weight 31 lb
Input Sensitivity: 1.0V
Connectors: Signal inputs and outputs – XLR NEUTRIK gold plated loudspeaker terminals 4x gold plated 5 way binding post for each channel
AC line voltage:110-120 VAC, 60 Hz
τιμή: $2200
Dual Mono ολοκληρωμένος A300S
Power Output: 2x110W/8ohm 2x170W/4ohm
Frequency Response: 20Hz-22kHz /0 dB –0.1dB; 3.3Hz and 190kHz / -1dB; 1.2Hz and 450kHz / - 3dB
Distortion THD+N (BW 80kHz): max 0.005% 20Hz–22kHz for output 8Vrms typical 0.002% / 1V
Inputs: 5 x Line Inputs RCA
Volume Control: Microprocessor Driven DACs; -112dB to 0dB in 0.5dB step
DC Offset: max 10mV; typical <5mV
Connectors: signal inputs and outputs - gold plated RCA; loudspeakers terminals - 4x gold plated 5 way binding post for each channel
Channel Matching: < 0.1 dB –112dB to 0dB
Outputs: 1 x tape output ; 1 x preamplifier output - regulated
AC line voltage: 110-120 VAC; 60 Hz
τιμή: $ 2,090.00
Χμμμ... για να δούμε θα ενδιαφερθεί κανένας αντιπρόσωπος εδώ???
![](/forum/proxy.php?image=http%3A%2F%2Fwww.bvaudio.com%2Fimages%2Fp10.jpg&hash=428333884b640688e5ce92351696e014)
Προενισχυτής P10
τιμή: $1790
![](/forum/proxy.php?image=http%3A%2F%2Fwww.bvaudio.com%2Fimages%2Fp3ix.jpg&hash=40cb81854be964bb259373303f4f9205)
2x200W RMS 4ohm
0.0018% /200W/4ohm,
τιμή: $2200
![](/forum/proxy.php?image=http%3A%2F%2Fwww.bvaudio.com%2Fimages%2Fa3.jpg&hash=0325621e501d337c8c7195cc71a728ef)
τιμή: $ 2,090.00
