Cadence Audio
CADENCE is India's first and only high end audio company.
Cadence VA 1.0
The Cadence VA 1.0 Specifications
Specifications
Power Output 36 watts RMS @ 1kHz into 6 Ohms 9 watts RMS (Pure Class A) into 6Ohms
Peak Power Output 50 watts into 6 Ohms
Freq. Response 3 Hz to 40 kHz (+ - 0.5 dB), @ 1 watt with Electrostats connected.3Hz to 100 kHz (+- 0.5 dB) into 6 Ohms at 1 watt
Rise Time 2.5 Micro Seconds @ 1 watt into 6 Ohms 8.00 Micro Seconds with Electrostat connected
THD <0.01 % @ 1 watt 20 to 20kHz in 6 Ohms
<0.1 % @ 10 watts into 6 Ohms
<0.6 % @ 36 watts (1kHz
IM Distortion
<0.01 % 250 Hz + 8020 Hz (@ 1 watt into 6 Ohms)
Dynamic Range 108 dB
Input Impedance 10 K Ohms
Output Impedance 6 Ohms ( 4 to 8 Ohms)
Damping Factor > 26
Input Sensitivity 1 V - 35 watts
Power Consumption 170 watts
Weight 50 Kgs.
Hybrid Valve Amplifier
CANASYA (Sanskrit : Delightful)
A no holds barred design incorporating the legendary 845 carbon triodes, these monoblocks deliver a stunning 200 Watts RMS per channel. Recognised by critics and audiophiles alike as one of the finest tube amplifier ever made, the Canasya delivers music as it was originally played. Combined with stunning design this amplifier has taken the audio world by storm.
ARCA
Cadence's flagship reference speaker, Cadence is the pride of our stable of products. From its dazzling design, to the new standards in construction, the ARCA has set new benchmarks for hybrid loudspeakers
Cadence DS
Cadence's entry level dynamic loudspeaker. The DS incorporates many of the design breakthroughs from our research on hybrids.
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Τα προϊόντα της Cadence είναι περισσότερο γνωστά στην Μ.Βρετανία, που είναι και η κύρια αγορά τους.(ο ιδιοκτήτης είναι Άγγλος που ζει στην Ινδία και έχει εκεί και την παραγωγή λόγω χαμηλού κόσοτυς, φορολογίας κλπ κλπ)
Τα υβριδικά της ηχεία είναι πολύ γνωστά και έχουν μια φοβερή ιδιότητα. Είναι προσαρμοσμένα στις καιρικές συνθήκες της Ινδίας και έτσι ακόμα και σε συνθήκες υψηλής υγρασίας σπάνια παρατηρούνται ηλ. εκκενώσεις μεταξύ τον στατόρων και της μεμβράνης...
Υπάρχουν πάρα πολλά τεστ σε Αγγλικά περιοδικά.
Έχω ακούσει τον τελικό με τις 845 και παίζει "παπάδες"....
Nick Arvanitakis
Audio Pro
ΠΑΙΔΙΑ ΤΑ ΑΚΟΥΣΑ ΠΡΙΝ 2 ΧΡΟΝΙΑ ΠΕΡΙΠΟΥ ΣΤΟ ΣΠΙΤΙ ΜΙΑΣ ΓΝΩΣΤΗΣ.ΗΤΑΝ 2 ΜΟΝΟ ΑΜPLIFIERS ME TIS 845(ΔΕΝ ΕΙΜΑΙ ΚΑΙ ΛΑΜΠΟΛΟΓΟΣ)ΝΟΜΙΖΩ PRE-AMP ΠΑΛΙ CADENCE ME ΠΟΛΥ ΩΡΑΙΟ ΜΠΛΕ ΦΩΤΙΣΜΟ ΚΑΙ ΗΧΕΙΑ ΥΒΡΙΔΙΚΑ ΜΕ 8" WOOFER ΣE MEΓAΛH KAMΠINA ΚΑΙ ΕΝΑ ΜΙΚΡΟ ΗΛΕΚΤΡΟΣΤΑΤΙΚΟ ΠΑΝΕΛ ΑΠΟ ΠΑΝΩ.ΜΟΥ ΕΚΑΝΕ ΑΝΤΥΠΩΣΗ ΤΟ ΠΟΣΟ ΚΑΛΑ ΕΠΑΙΞΕ ΑΝ ΚΑΙ ΜΟΛΙΣ ΕΙΧΕ ΒΓΕΙ ΑΠΟ ΤΑ ΚΟΥΤΙΑ
TimoleonTimoleon
