Cambridge Audio Azur 650R 7.1 AVR
Σε συνεχεία αυτού το ταίρι:
Κλικ
Azur 650R 7.1 HDMI 1.3 AVR features
Three fully assignable HDMI 1.3c inputs for Blu-ray/DVD players, HD satellite receivers and games consoles Latest generation Cirrus CS49700 chipset features twin 32-bit DSP cores for compatibility with the latest CODECs including Dolby Digital Plus, DTS- HD High Resolution and the Lossless Dolby True HD and DTS-HD Master Audio formats Full support for analogue or digital legacy formats – LPCM, Dolby Digital, Dolby Digital EX, DTS, DTS ES Matrix, DTS ES Discrete, DTS 96/24, Neo:6, ProLogic II, ProLogic IIx, in 5.1, 6.1 or 7.1 variants DTS Speaker re-mapping allows the playback of DTS-HD High Resolution or Master Audio formats with encoded height information on standard 5.1, 6.1 or 7.1 speaker setups Fully supports multi-channel PCM over HDMI for DVD-A/SACD and other external audio formats 24 bit A/D conversion for digitally processed analogue modes Pure Analogue Stereo Direct mode for audiophile playback of analogue stereo sources. Full post-processing of 2.0, 5.1 or 6.1 material is also possible with PLIIx or DTS Neo:6 to turn these formats into 7.1 Analogue to digital video transcoding (composite, S-video and component video to HDMI) True power output of 7 x 100 watts rms per channel, 8 ohms all channels driven Analogue stereo direct mode for audiophile stereo sources (pure analogue, no DSP) – 120W output x 2 Oversize low flux toroidal transformer Cambridge Audio Mic Controlled Auto Set-up (CAMCAS) with microphone supplied On-Screen Display (OSD) available on all video outputs Adjustable LipSync delay feature New optional bi-amping mode for front left/right with surround back left/right in 5.1 set-up FM/AM tuner with RDS X-Tract™ Forced/Convection Heat Tunnel for virtually silent performance Fully specified for custom install applications such as Incognito Ready™ multi-room outputs, RS232 port, IR emitter In, Control Bus In/Out Navigator style Azur remote control Completely new wrap-around casework
Τιμή $1799
(ας βάλει κάποιος και μια φώτο γιατί δεν μπορώ τώρα)
PTin
