CAMBRIDGE AUDIO DACMAGIC PLUS
Πωλείται το DAC - PREAMP του τίτλου σε μαυρο χρώμα με κάποια σημάδια χρήσης στο απο κάτω μέρος του σασί μόνο, κατά τα άλλα σε άριστη κατάσταση,
στα 300 ευρώ
Technical Specifications
Digital to analogue convertersDual Wolfson WM8740 24-bit DACs
Digital filterAnalog Devices ADSP21261 DSP; upsampling to 24-bit/384kHz
Analogue filter2-Pole Dual Differential Bessel Double Virtual Earth Balanced
Frequency response20Hz to 20kHz (±0.1dB)*
THD @ 1Khz 0dBFs<0.001% 24-bit
THD @ 1kHz -10dBFs<0.001%
THD @ 20kHz 0dBFs<0.002%
Signal to Noise Ratio-112dBr
Total correlated jitter<130pS
Crosstalk @ 1kHz< -130dB
Crosstalk @ 20kHz< -112dB
Output impedance<50 Ohms
Max. output level (unbalanced)2.1V rms
Max. output level (balanced)4.2V rms (2.1V per phase)
Digital input word widths supported16-24bit
Digital input sampling frequencies supported32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz**, 192kHz
Audio output upsamplingFixed 24-bit/384kHz
Max power consumption12W
ColourBlack or silver
Dimensions (HxWxD)52 x 215 x 191mm; (2.0 x 8.6 x 7.6”)
Weight1.2kg/2.6lbs
Headphone output
THDat 1kHz 0dBFS 24-bit signal with 22kHz low pass filter = 0.001% at 20khz 0dBFS 24-bit signal with 80kHz low pass filter = 0.003%
S/N-111dBrA
Frequency response10Hz - 100kHz
Recommend headphone impedance 32 Ohm to 600 Ohm
*Steep filter disabled
**Digital 1 & 2 Inputs only
Whats in the boxDac Magic Plus Digital to Analogue Converter, Quick Start Guide, Safety Guide, PSU (12V DC / 2A), Adapator, USB cable, Rubber feet x 4pcs, Rubber base stand
kotsos134
