Cambridge audio NP 30 streamer /radio
Το streamer με το κουτι του
DAC Wolfson WM8728 24-bit/96kHz capable
THD+N
0.003% @ 1kHz
SIGNAL TO NOISE RATIO
> 95dB
TOTAL CORRELATED JITTER
<200pS
DIGITAL OUTPUTS
S/PDIF Co-axial and TOSLink Optical 16-24 Bits, 22.05-96kHz
AUDIO FORMATS
WAV containing uncompressed PCM 16-24 bit 32-96kHz FLAC containing losslessly compressed PCM 16-24 bit 32-96kHz Apple Lossless (ALAC) 16-24 bit @ 12/16/22.05/24/32/44.1/48/96kHz AIFF containing uncompressed PCM 16-24 bit 32-96kHz Microsoft® Windows MediaTM Audio (WMA 9 Standard) 32-320kbps MP3 (CBR or VBR) 16-320kbps, AAC, HE AAC and AAC+ (CBR or VBR) 16-320kbps Ogg Vorbis 32-320kbps (88.2kHz sampling frequency not supported)
STREAMING PROTOCOLS
RTSP (Real Time Streaming Protocol) MMS (Microsoft Media Server Protocol) HTTP (Hyper Text Transfer Protocol)
WI-FI
IEEE 802.11 b / g or n (Ethernet connection required for 24-bit files)
WI-FI ENCRYPTION
WEP, WPA, WPA2
ETHERNET
IEEE 802.3,10 Base-T or 100 Base-T
USB
2 x USB 1.1 current limited to 500mA each
FILE SYSTEMS
FAT32
TRIGGER IN
12V DC
MAINS INLET VOLTAGE
120-240 VAC (switch mode)
STANDBY CONSUMPTION
<1W
MAX POWER CONSUMPTION
21W
DIMENSIONS (H X W X D)
67 x 270 x 285mm (2.6 x 10.6 x 11.2")
WEIGHT
2.1kg (4.6lbs)
Στα υποψιν μπορει να οδηγησει και απευθείας ενεργα ηχεία με τον προενισχυτη του !!!;)
Παιζει spotify ,τα παντα απο αρχεια εκτος dsd.
Τιμη 220 €
  • Like
Reactions: PPG
mmapollo
