Car PC
gkontoletas
trouble in my brain
http://www.kingyoung.com.tw/S625FC.htm
http://www.kingyoung.com.tw/S625C.htm
Here are the full specs:
S625F
# Processor
Intel Pentium M processor or Celeron M processor (Dothan or Banias) up to 1.8GHz (FSB400MHz)
# Memory
Support 0.8" low profile DDR 333/266 DIMM, Maximum 2 GB
# Core Logic
Intel 855GME / ICH 4(North / South)
# Video
Intel Extreme Graphics 2
Support up to 64MB DVMT video memory
# Audio
Software AC '97 Audio CODEC
# LAN
Built-in high speed Ethernet 100/10Mbps LAN controller
# FireWire
Built-in OHCI 1394a 1.1 compliance
Support up to 400Mb transfer rate
# USB 2.0
Integrated 3 independent OHCI controller supporting USB 1.1 ports
Integrated 1 EHCI controller supporting USB 2.0 ports
Dynamic connection support to USB 2.0 or USB 1.1 devices
# IDE
Dual Independent ATA-100/66/33 support
Support up to 4 IDE devices on dual channel
# Hardware Monitor
System, processor temperature, voltage
# Power Management
ACPI 1.0b compliance and OS direct power management
Wake-on event: RTC/USB Keyboard/Modem/LAN/Keyboard/Mouse
# Switch and Jumpers
Front Panel:
1 x IEEE 1394 Firewire port
1 x USB 2.0 / 1.1 Port
1 x MIC Port
1 x Ear Phone output Jack
Power-on button
Reset button
Power-on and HDD LED
Back Panel:
1 x RS232 COM port
1 x parallel printer port
1 x RJ45 10/100Mb Fast Ethernet
1 x Line-Out output Jack
2 x USB 2.0 / 1.1 Ports
1 x 15 pin VGA
1 x DC Power Jack Input With Lock
# Dimension & Weight
14.6 x 25 x 4.2 cm
1.5KG (fully equipped)
# DC Input
10 ~ 16V DC Input
# Storage Devices
Support all Standard Slim CD-ROM/DVD-ROM, CD-RW, DVD-RW Combo
Support all 2.5" standard IDE hard drive, ATA-100/66/33
S625FC
Specifications
# Processor
Intel Pentium M processor or Celeron M processor (Dothan or Banias) up to 1.5GHz (FSB400MHz)
# Memory
# Core Logic
# Video
# Audio
# LAN
# FireWire
# USB 2.0
# IDE
# Hardware Monitor
# Power Management
Front Panel:
1 x MIC Port
Power-on button
Reset button
Back Panel:
1 x RS232 COM port
1 x 15 pin VGA
15.5 x 25.5 x 5.5 cm
2.5KG (fully equipped)
# DC Input
10 ~ 16V DC Input
# Storage Devices
Gebreselassie
Μαύρος!
Σύντροφε gkontoleta, δυστυχώς δεν είχα δει το θέμα σου...
Ψάχνω την υπόθεση car pc εδώ και πάρα πολύ καιρό...
Θεωρώ την ιστορία του car pc ως το μέλλον σε θέματα ψυχαγωγίας εντός αυτοκινήτου και πραγματικά απορώ γιατί οι εταιρείες δεν έχουν ήδη να επενδύουν σε αυτό.
Είναι το μόνο μηχάνημα που μπορεί να μας εξασφαλίσει μουσική (cd, dvd, mp3), internet, ταινίες, tv, το καλύτερο GPS που μπορούμε να ονειρευτούμε ποτέ, αλλά και ένα κάρο άλλες εφαρμογές. Και όλα αυτά με ένα μηχάνημα 1DIN στην θέση του ταπεινού κασεττοφωνακίου μας...
Η ερώτηση είναι απλή.
Έχει ασχοληθεί κανείς? Ψάχνουμε πηγές, κυρίως εντός Ελλάδος, για αγορά parts και συναρμολόγηση των δικών μας car pc. Touch screen οθόνες υπάρχουν ένα κάρο στην πιάτσα. Το λέω γιατί υπάρχουν 2-3 εταιρίες που ασχολούνται με car pc αλλά δίνουν έτοιμες λύσεις και μάλιστα αρκετά τσιμπημένες.
Οποιαδήποτε βοήθεια ευπρόσδεκτη...
Είναι σχεδόν "παρθένα" η αγορά Νίκο!!
Αλλά, εσύ που είσαι μέσα στο "μέλι" γιατί δεν το ψάχνεις περισσότερο???
Gebreselassie
Μαύρος!
Γιάννη είναι πολύ δύσκολο. Επικρατεί πλήρης άγνοια και επί του παρόντος δεν δείχνει κανένας να ενδιαφέρεται επιχειρηματικά (πραγματικά δεν καταλαβαίνω το γιατί...), γι αυτό και δύσκολα βρίσκεις λύσεις εντός Ελλάδος.
Gebreselassie
Μαύρος!
Καλό.
Η VIA δείχνει να έχει το 90% της εν λόγω αγοράς. Όπου και να κοιτάξω ειδικά σε έτοιμα μηχανάκια, VIA βλέπω...
Christos Kourmouzoglou
