Πωλείται το άνωθεν καλώδιο του τίτλου (εκ μέρους του πεθερού μου) σε άψογη κατάσταση .
Golden Reference speaker is the latest evolutionary speaker cable design by George Cardas. It features Cardas patented "Golden Section", multi-gauge stranding in a symmetrical, 12 conductor, helical triad of quad-axial planetary arrays of golden ratio, constant Q conductors.
Cardas patented, "Constant-Q" construction places the smallest of the Golden Ratio strands at the center of the conductor to reduce stored energy and conductor resonance. Cable resonance is further reduced with controlled propagation, Crossfield construction, matching conductor and cable loop characteristics with carefully computed strand layering. Cross layered conductors reduce EMI and RFI to a new low. All conductors are individually coated to insulate and prevent oxidation.
Golden Reference is a perfectly neutral reference cable with unmatched transient purity. Golden Reference is perfectly symmetrical and non directional. Like all Cardas cable, Golden Reference is individually inspected, and hand terminated using Rhodium plated connectors and Cardas formulated Quad Eutectic solder, for a lifetime of listening pleasure.
Reviews
SoundStage! Equipment Review - Cardas Audio Golden Reference Interconnects and Speaker Cables (2/2005)
SoundStage! Network Ultra Audio -- Archived Article
cardas_golden_reference
Τιμή 1100 euro .
Τα καλώδια έπαιζαν εδώ.
- Outside Diameter: .702
- Dielectric Type: Teflon®, Air
- Inductance: .031 uh/ft/loop
- Capacitance: 216 pf/ft
- Bi Wire Option: Yes
- Tri Wire Option: Yes
- Discrete Conductors: 816
- Cable AWG: 5
- Conductor Type: Matched Propagation, Golden Ratio, Constant Q, Crossfield, Pure Copper Litz
Reviews
Τιμή 1100 euro .
