CARY 306 SACD
Πωλειται το cd της cary 306 sacd σε κατασταση καινουργιου χρωμα μαυρο απο 8000 χιλιαδες που εκανε καινουργιο 3500ευρο τηλ.6974724609 δεκτη ανταλλαγη με προενισχυτη McIntosh c 2300 η αλλον ισης αξιας
CD-306 SACD Specifications
  • Weight: 50 lb.
  • Dimensions: 5" H x 18" W x 15" D
  • Transport: SCD-1
  • Master Clock Jitter: Below measurable levels, with a digital buffer circuit to eliminate jitter.
  • Digital Sample Rates (Fs): 44.1, 96, 192, 384, 512 or 768kHz sample rates for CD playback to the analog audio outputs, 44.1, 96 or 192kHz Fs for digital inputs
  • Digital/Analog Converters: 8 Burr Brown PCM-1792u, four per channel
  • Analog Filter: 3rd Order Bessel
  • Analog Outputs: Balanced XLR, Single-Ended RCA
  • Digital Outputs: AES/EBU, Coaxial, Toslink (1 each)
  • Digital Input: AES/EBU, Coaxial, Toslink (1 each)
  • Digital Input Sample Rate: 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz or 192kHz, Accepts 16, 20, or 24 bits
  • Frequency Range: 2Hz - 80kHz (@ 192kHz)
  • Amplitude Linearity: 0.1dB (20Hz - 20kHz)
  • Phase Linearity: 3 degrees (20Hz - 20kHz)
  • Dynamic Range: 130dB (1 kHz)
  • Signal-to-Noise Ratio: 133 (1kHz)
  • Channel Separation: 110 (1kHz)
  • Total Harmonic Distortion: 0.0008% (1kHz) THD
  • Audio Output Level: Single-Ended 3.0 Vrms, Balanced XLR 6.0 Vrms
  • Power Input: Configured at the factory for 100-120 or 200-240 Volts AC @ 50-6
Lp's21
