vlasis
Φωτογράφος!
XCITER Series
D/A USB converter
The Cary Audio Xciter DAC is the perfect match for the Xciter integrated amplifier! Compact desktop 192 kHz/32 Bit DAC featuring the new AKM4399 32-Bit DAC along with the new National Semiconductor metal can LME49713NA and LME49710NA output devices. These National Semi devices were specifically designed for Cary Audio Design. The Xciter DAC features a computer USB input along with optical input and two coaxial inputs. The inputs are selectable from the front panel. Front panel LED's will indicate the incoming sample rate up to 192 kHz.
Input Receiver AK4115 & CM108 Digital to Analog Converters AK4399 Digital Inputs 4 selectable inputs - Coaxial single-ended, Coaxial BNC, Toslink, USB
(Gold Plated) Analog Output RCA analog output Input Sample Rates Accepted 44.1KHz, 48KHz, 96KHz, 192KHz Bit Depths Accepted 16 – 24 bit, LPCM 2ch audio stream Capacitors Panasonic electrolytic capacitors, Tantalum capacitors & WIMA polyester film
and foil capacitors Power Transformer Dual C core power transformer Dynamic Range 117dB Signal to Noise Ratio 109dB Noise and Hum -101 dB below rated output Audio Output Level 2.0V RMS 200 Ohm output impedance Frequency Response 20Hz – 22KHz (44.1KHz) Wiring Printed Circuit Board and custom point to point cabling AC Cord 3 Conductor Shielded, Detachable AC Power Requirements 117 VAC @ 50/60 Hz
234 VAC @ 50/60 Hz
http://www.caryaudio.com/products/xciter/XciterDAC.html
D/A USB converter
234 VAC @ 50/60 Hz
