Πωλειται το παραπανω hdcd player πραγματικα σε υπεραριστη κατασταση με το μανιουαλ του και πληρη συσκευασια.
Τιμη 750 ευρω.
Παρακαλω οχι ανταλλαγες.
CD MechanismTriple-beam laser, multi speed CD/DVD ROM transportFormatsCD AUDIO (CD-DA), CD-R, CD-RWMaster Clock JitterBelow measurable levelsDigital FilterCARY DSP-300 with HDCD decodingDigital/Analog Converters(2) Burr Brown PCM 1792UAnalog Filter3rd Order BesselAnalog OutputsBalanced XLR, Single-ended RCADigital OutputsCoaxial, Toslink, Fs from 44.1 kHz 16 bit to 192 kHz 24 bitFrequency Range2 Hz to 22 kHz (44.1 kHz)Amplitude Linearity0.1 dB (20 Hz - 20 kHz)Phase Linearity3 degrees (20 Hz - 20 kHz)Dynamic Range129 dB (1 kHz)Signal-to-Noise Ratio122 dB (1 kHz)Channel Separation104 dB (1 kHz)THD0.003% (1kHz)Audio Output Level3.0V RMSBalanced6.0V RMSTrigger Input12V DCIR InputPHILIPS RC 5 IR codeCommunicationsRS232 full remote/configuration interfaceAC Power Input100 to 120 or 200 to 240 VAC 50-60 HzPower Consumption50 wattsWeight23 lbs. Dimensions4.5" H x 17" W x 13" D
Τιμη 750 ευρω.
