Teac PD-H 600 Reference Series - σε άψογη κατάσταση.
PD-H600 SPECIFICATIONS
http://audio.teac.com/product/pd-h600/overview/
Reviews:
http://www.soundstageaccess.com/equipment/teac_pd_h600.htm
http://avmentor.gr/reviews/teac_pdh600_agh600nt_0.htm
https://www.whathifi.com/teac/reference-600/review
Τιμή: 430 ευρώ
Συναλλαγή με συνάντηση - Αθήνα - Κέντρο, ακρόαση και δοκιμή δεκτή.
- Compatible Discs: CD-DA, CD-R/RW, MP3, WMA
- Frequency Response: 20Hz - 20,000Hz (±0.5dB)
- Total Harmonic Distortion: Less than 0.003% (1kHz)
- Signal-to-Noise Ratio: more than 110dB (1kHz, 0dB, A weight)
- D/A Converter: 24bit/192kHz Delta-sigma (PCM1796)
- Oversampling Rate: 8-times
- Repeat Play: Yes (1, All)
- Shuffle Play: Yes
- Program Play: Yes (30 Tracks)
- Display: Fluorescent Dot-matrix
- Display Dimmer: Yes (Normal, Dimmed, Off)
- Audio Output: RCA (Gold-plated, 2.0Vrms, 1kHz, 0dB)
- Digital Output: Coaxial (Gold-plated, 0.5V, 75 ohms)
- Signal Ground Terminal: Yes
- Remote system connection for use with AG-H380
- Power Requirements: 120V, 60Hz (US), 230V, 50Hz (EUR/Asia)
- Consumption Power: 9W (Standby: 0.7W)
- Dimension (W x H x D): 11.4" x 4" x 12.1" 290 x 102 x 308mm
- Weight: 11.9 lbs. 5.4kg
Reviews:
