Cec St930
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Ένα πολύ ωραίο πικάπ που βρήκα στο site της CEC. Ξέρει κανείς κάτι παραπάνω για αυτό???
The belt driven turntable ST 930 is the result
of our long term history in development of turntables
* Belt drive system with high flywheel mass
* 3 phase brushless FG Servo Motor
* Turntable with additional damping 320 mm diameter
* 3 speeds 33 / 45 / 78 U/min
* Wow & Flutter less then 0,008%
* Signal to noise ratio DIN A more than 50 dB
* Signal to noise ratio Din B more than 85 dB
* Tonearm
* Oil damping gimpal support system
* Effective length 229 mm
* Overhang 15 mm
* Adjustable stylus force 0 - 30 mN
* Dimensions
* Turntable 485 x 350 x 85 mm without dustcover
* Control Unit 100 x 220 x 85 mm
* Weights
* Turntable 9 Kg
* Control Unit 1.2 Kg
giannisx4
