ClairAudient LSA 16 Loudspeaker
vlasis
Φωτογράφος!
The ClairAudient LSA (line source array) is a loudspeaker system, designed by the late Richard Smith, a co-founder of Audience, LLC. Richard’s dream was to design a loudspeaker without any of the usual design compromises that, in one way or the other, limit every loudspeaker system known today. Loudspeaker designers typically just find different ways of improving on various limitations. A little know fact is that Audience was founded in 1997 to make loudspeakers; not just any loudspeaker, however specifically the design that has culminated as the ClairAudient LSA. The idea was to avoid working around conventional loudspeaker design limitations by designing a loudspeaker that was free of those limitations in the first place.
The ClairAudient LSA has no crossovers.
http://www.audience-av.com/loudspeakers/
Τα νεα ηχεια της Audience και οι νεοι πυκνωτες με τεφλον με ονομασια AURA T....
http://www.audience-av.com/capacitors/t_description.php
The new Audience Teflon capacitors are simply the best caps I've used. They are very balanced from top to bottom, fast, detailed and yet very natural sounding. They provide excellent authority across the band and give a life like presence beyond what I've experienced before! All in all, if you're going for the ultimate in audio performance I'd highly recommend them.
PRICE LIST
VALUE
DESCRIPTION
DIMENSIONS
1-24
25-49
1.000
µF 5% 200V
1.25 X 1.98
$105.68
$72.00
3.000
µF 5% 200V
1.90 X 2.00
$221.83
$151.01
6.000
µF 5% 200V
2.2 x 2.43
$353.45
$240.53
auraT
VALUE
DESCRIPTION
DIMENSIONS
1-24
25-49
0.015
µF 5% 600V
.67 X .80
$29.91
$20.47
0.100
µF 5% 600V
.93 X 1.40
$67.81
$46.25
0.220
µF 5% 600V
1.05 X 2.0
$106.00
$72.22
0.330
µF 5% 600V
1.27 X 2.0
$154.55
$105.25
0.470
µF 5% 600V
1.45 X 2.0
$212.08
$144.37
0.680
µF 5% 600V
1.52 X 2.40
$267.69
$182.20
1.000
µF 5% 600V
2.20 X 2.05
$407.96
$277.60
3.000
µF 5% 600V
.90 X 1.10
$1065.70
$724.96
gvts
