The company's latest amplifier offering, the Omega Omicron Mono-block amplifier, produces 300 watts into an 8-ohm load, 600 watts into a 4-ohm load or 1,200 watts into a 2-ohm load. The amplifier comes equipped with both balanced and unbalanced RCA connections, and it employs a large regulated DC power supply and extended capacitance reservoirs, which ensure consistent performance with no sags in power. Classe offers the Omega Omicron in a two-toned billet-aluminum finish.
SPECS:
Frequency response: 20Hz-20kHz
Distortion THD + Noise: 0.002%
Output
300W into 8 ohms
600W into 4 ohms
1200W into 2 ohms
Power Supply
Transformer size: 1620 VA
Number of capacitors: 64
Total capacitance: 201,600µF
Inputs
Single-ended: 2.25V/100KΩ
Balanced: 2.25V/100KΩ
(volts for full output/impedance)
Weight & measurements
Net weight: 50kg
108lbs
Height: 419mm
16.5"
Width: 254mm
10.0"
Depth: 495mm
19.5"
ΤΙΜΗ:MSRP: $10,000 ο καθένας
