Concrete Audio F1
m1ts0s
News poster
The F1 is an innovative multipurpose wall mounted loudspeaker designed for use in different spaces and to compliment interior design – Ultra flat, active and wireless.
Patented array-technique of the Fraunhofer IDMT – 41 electrodynamic mini-speakers act like one large membrane, allowing for a total depth of only 32 millimetres and giving a convincing performance.
Audiofly Syncronice wireless
Audiofly HighEnd Wireless Audio – Listen to music in CD quality with a smartphone, tablet or streamer.
Enjoy synchronised sound from a TV or games console without delays.
Uncomplicated & individually
The F1 is simple to install and operate.
Decorative – Stand out with a pure concrete design or choose from a wide range of colours and surface finishes.
Discreet – Combine the F1 with aluminum or real wooden frames or add a reversible cover with individual motif.
TECHNICAL SPECIFICATIONS MODEL F1
Housing: Concrete, monolithically poured
System: 2-way-array, closed-box, active, DSP, Class-D
Frequency range: 100 Hz – 20,000 Hz
Max. SPL/1 m: 98 dB (10 % THD at f = 100 Hz; < 3 % THD at f > 200 Hz)
Dimensions (H x W x D): 57,5 cm (22,6 in) x 39 cm (15,4 in) x 3,2 cm (1,3 in)
Net weight: 12 kg (26,4 lbs)
analog: Line-In balanced/unbalanced
digital: Audiofly Syncronice wireless
The technical data of the CONCRETE AUDIO F1 is the result of an extensive acoustic survey by the Fraunhofer Institute for Digital Media Technology IDMT, Ilmenau. The data was charted using a low reflection chamber of the Class 1 (according to ISO 3745) to Requirements of DIN 60268-5.
Technical data Audiofly Syncronice wireless device:
48 kHz, 16 bit I2S Digital Audio
20 Hz to 21 kHz Frequency Response
2.4 GHz Frequency Band
High Quality of Service (QoS)
Very high signal stability with adaptive frequency hopping.
Inaudible delay with extremely low latency
HPX™ Audiocodec
THD+N better than 0,01%
All systems run without drivers and Apps
Fast and simple expansion
24 bit, 96 kHz Stereo D/A- Convertor from Cirrus Logic
http://www.concrete-audio.com/en/
m1ts0s
News poster
Concrete Audio B1
The B1 is an active bookshelf speaker for straightforward enjoyment of music in its best possible quality. The equipment with a fullrange driver and two opposed midwoofers in an enclosed concrete cabinet devoid of resonance, enables the listener to experience extremely vivid and faithful sound.
Efficient Class-D technology and multifaceted adaptability via a digital signal processor (DSP) render the B1 a full-featured sound system with countless options, only to be completed by a source of your choice.
TECHNICAL SPECIFICATIONS MODEL B1.
Housing:
System:
2-way closed-box, active (Class-D, DSP)
Frequency range:
45 Hz – 20.000 Hz
Power handling (RMS/max.):
120 / 240 W
Total Harmonic Distortion:
< 0,07 %
Signal-Noise-Ratio:
92 dB
DSP Sampling Frequency:
48 kHz
DSP resolution:
56 Bit
DSP speed:
50 MHz
AD converter resolution:
24 Bit
DA converter resolution:
24 Bit
Ports:
– Line-In, Jack-Socket 3.5 mm, 10 kOhms, 0.2 V / 2.0 V RMS
– Sub-Out, Jack-Socket 3.5 mm
– Bluetooth V3.0 + EDR und aptX-codec-support
– Audiofly Syncronice (optional)
Remote control:
IR
Dimensions (HxWxD):
39 cm x 16 cm x 29.5 cm
15.4 in x 6.3 in x 11.6 in
Weight:
18 kg (39.7 lbs)
3490 ευρώ ζεύγος
https://www.concrete-audio.com/en/#kompaktlautsprecher_b1
Είναι πολύ μικρό Κώστα.
Εντάξει, κουβαλάει πολύ τεχνολογία, και καμπίνα από τσιμέντο, αλλά μικρά μεγάφωνα, μικρές δυνατότητες.
Η εμπρός μονάδα, δεν με έπεισε πάντως. Μπορεί να είναι λάθος βέβαια αυτή μου η εκτίμηση, αλλά όχι αυτή που αφορά μέγεθος μεγαφώνων και κατά συνέπεια δυναμικά και στάθμες.
Πολλά λεφτά για στάθμες ασανσέρ...
Έχει βέβαια έξοδο για σαμπ, και δυνατότητες ασύρματης διασύνδεσης, έχουν κάνει δουλειά οι άνθρωποι, πιθανώς να είναι πολύ ανώτερη επιλογή από το μικρό κεφ.
Εαρ τα ακούσαμε στο Μόναχο, δεν θυμάσαι μάλλον. Την πρώτη μερα.
Τίποτα φοβερό.
Μια χαρά τα θυμάμαι βρε...
Γι'αυτό έγραψα πως δε με έπεισε...
Konstantinos M.
