Consonance M400S EL34 Monoblock 40w
Push-Pull Vacuum Tube Power Amp
Control Functions: Power on/off toggle at rear
Inputs: RCA left & right
Output Impedance: 4 or 8 ohms, user selectable
Output Power at 1 kHz for less than 1%THD: 40 x 2
Bandwidth at -3dB: 6Hz to 60Hz
Signal to Noise: 90 dB
Input interfaces: 1 group (RCA)
Input impedance: 100k
Power consumption: 90w x 2
Tubes: EL34 x 4; 6922 x 2; 6189 x 2
Dimensions: 355 L x 200 H x 150 W mm x 2
Weight: 11kg x 2 (Net); 22kg (Shipped)
SRP: $1995 pr.
Rear Panel of M-400s
There are three 5-way speaker terminals. The two hot terminals offer a choice of 4 ohm or 8 ohm output. The small on/off toggle switch is visible next to them, as well as the receptacle for the detachable AC cord.
REVIEW:
http://www.audaud.com/audaud/JAN-FEB05/component/comp2.html
SRP: $1995 pr.
REVIEW:
