D-Link DAP-1522 4-Port GigaBit Wireless N
Πωλείται το D-Link DAP-1522 Xtreme 4-Port GigaBit Selectable Dual Band Draft 802.11n N Duo Wireless Bridge/Access Point σε άριστη κατάσταση, στο κουτί του, με απόδειξη αγοράς.
- The Wireless Bridge feature of the DAP-1522 allows you to easily connect up to 4 Ethernet devices
- Create a new wireless network using the Access Point feature by connecting the DAP-1522 to an existing wired network
- 5GHz is ideal for wirelessly streaming multiple HD videos across your network.
- Use the Xtreme N Duo Wireless Bridge / Access Point (DAP-1522) to connect up to 4 Ethernet-enabled devices
- Connect the DAP-1522 to an existing wired network and easily enable wireless connectivity in your home.
Τιμή: 50 euro με έξοδα αποστολής δικά μου με ACS.
    Shalom
FotisLam
