DAC L.K.S AUDIO MH-DA004 Dual ES9038pro πωλείται
Πωλείται σε υπερ-άριστη κατάσταση το εν λόγω Dac, για όσους λίγους γνωρίζουν.
Ειναι κατασκευή μιας μικρής παραγωγής από κίνα. χειροποίητη.
Παρακάτω τα χαρακτηριστικά.
Σημερινή αξία αγοράς περί τα 1400,00$. + μεταφορικά τελωνεία κτλ.....
Ο ήχος δεν περιγράφεται εδώ μέσα. θα ήταν περιττά.
Τιμή 600,00Ευρώ.
Το dac είναι Θεσσαλονίκη. Τηλ επικοινωνίας 6980565666.
Μερικά σχόλια του κατασκευαστή:
ES9038pro is ESS's flagship DAC audio decoder chip, is currently able to see the highest performance index DAC chip, according to the practice of Mu, the use of two ES9038pro, respectively, work in the mono MONO mode, making two DAC chip Individually deal with the left and right channel audio content and do not interfere with each other, greatly enhance the DAC's performance and auditory effects. Mono MONO mode The official indicator is the dynamic range of 140dBA, which is 3dB higher than 137dBA when working with a single two-channel channel. The official indicator is for reference only, but it is easy to see that the monaural MONO Mode, the signal output current of the DAC is twice as high as that of the two-channel mode, and the darkness of the sound background, the density of the sound, the degree of separation, the motion, the knot, etc. can be made significant Of the promotion.
Specifications ---------------------------------
1. Two-chip ES9038pro decoding method.
2. Two high-quality toroidal transformers, a total of 13 groups of linear power supply.
3. Built-in specially designed Italian Amanero USB module, original license license. USB module added to isolate the chip, you can isolate the computer to the audio system interference signal.
4. Supports USB, I2S / DSD single-ended signal (RJ45), I2S / DSD balanced signal (HDMI), oaxial, BNC, AES / EBU balance, Optical total seven-way source input, all ports support DSD input.
5. Analog audio output port includes standard RCA single-ended output and XLR balanced output pair.
6. Display with VFD display, the display exceptionally outstanding.
7. Use physical key operation.
8. Support 0dB ~ -127dB digital volume adjustment, 0.5dB level. But also has a remote key to skip the volume adjustment function.
9. Support a variety of digital filter mode settings (see user manual). Can be arbitrarily selected, different filter mode, the digital filter attenuation characteristics are different.
10. Supports decoding of internal digital phase-locked loop bandwidth settings (see user's manual for details).
11. Support Deemphasis to increase or turn off.
12. The display has 4 levels of brightness adjustable. Adjusted by remote control.
13. Remote start, standby function.
14. Most of the settings with memory function, turn off the opportunity to automatically save the settings, restart the settings.
15. Dynamic range> 135dB
16. Distortion <0.0002%
17. Stereo resolution> 120dB
18. RCA unbalanced port output amplitude 2Vrms, XLR balanced port output amplitude 5Vrms.
19. Machine size 430 * 320 * 90mm
20. Machine weight 7.0kg
Παρακαλώ να κλείσει η αγγελία. Έχει πωληθεί, ευχαριστώ για την φιλοξενία.
opanamas
