DALI Callisto
m1ts0s
News poster
Touch Sensitive Volume
The touch sensitive panel atop the CALLISTO speaker cabinet lets you control the volume at the touch of your finger tip. The included Bluetooth remote & the Sound Hub's volume knob gets the job done just as easily. Regardless of your approach, the actual volume change is done at the very end of the signal chain.
SMC Technology
The CALLISTO woofers benefit from patented Soft Magnetic Compound (SMC) in the pole piece. The result is an extremely agile, well-behaving, ultra low-loss woofer with a significant reduction of distortion from mechanical loss.
Wood Fibre Cones
The low-mass CALLISTO wood fibre cones are optimised to work in perfect balance with the built-in amplifier. This enables the woofers to be more linear than in a similar passive speaker system. This is possible, as we have total control of the entire audio chain.
Class D Amplifier
The CALLISTO Class D amplifier is based on patented state-of-the-art technology with a global feedback and self-oscillating design, chosen for its very musical properties. It's able to deliver 250 Watts for up to 5 secs, ensuring plenty of power even in complex musical passages or massive movie explosions.
Whether you’re listening to music from an online streaming service, a Hi-Res download or a CD/record player, we believe you should hear music as the artist intended. With a host of inputs, from traditional wired connections to Bluetooth Apt-X HD and AAC – plus two future-proof expansion ports (e.g. BluOS) – CALLISTO is ready to connect the way you want it to.
At the heart of the system, the DALI Sound Hub brings true no-compromise convenience to music and movie lovers. It transmits Hi-Res audio in true HD quality (24bit/96KHz) to your CALLISTO speakers, while you take control of the hub with your mobile device. The Sound Hub will automatically switch to whichever source is connected and can be hidden out of sight if desired, as the remote control connects via Bluetooth.
Callisto 2C (€2800/ζεύγος)
Callisto 6C (€3600/ζεύγος)
DALI Sound Hub (€600)
https://www.dali-speakers.com/loudspeakers/callisto/
ztv
