Dali SWA-12 Subwoofer
Καλησπερα πουλαω ολο τον Home Cinema εξοπλισμο μου, λογω μετακομισης σε αλλη χωρα.
Πωλειται σε πολυ καλη κατασταση το Subwoofer της Dali SWA-12 .
Αγοραστηκε καινουργιo απο μενα το 2001-2002.
Dali SWA-12 Subwoofer .Designed and Hand-Built in Denmark.
12" bass driver with 120W power.
Specs:
Frequency range (+/- 3dB) [Hz]: 27 - 150
Maximum SPL [dB]: 112
Crossover frequencies: 50 - 150
Low frequency driver: 1 x 12 " Air-dried paper cone
Enclosure type: Closed box
Continous IEC Power Output [RMS Watts]: 120
Maximum power consumption [W]: 260
Idle power consumption [W]: 15
Connection input(s): Stereo speaker level (low pass filtered)
Stereo "line level" (low pass filtered)
Recommended placement: Sub
Connection output(s): Stereo speaker level (high pass filtered)
Stereo "line level" (high pass filtered)
Loudspeaker type: Subwoofer
Max loudspeaker dimensions incl. base and grille (HxWxD) [mm]: 365 X 455 X 455
Loudspeaker weight including base and grille [kg]: 19,7
Τιμη 300 ευρω.
Τηλ. 6973982074 - Χρηστος
Περιοχη Α.Γλυφαδα
http://i269.photobucket.com/albums/jj54/psihiatros/2005-111.jpg
http://i269.photobucket.com/albums/jj54/psihiatros/bild.jpg
http://i269.photobucket.com/albums/jj54/psihiatros/The-Dali-SWA-12-Subwoofer-1.png
icaris
