Sonorus
Πωλείται το ντακάκι ddHiFi TC44B. Με ενσωματωμένο καλώδιο usb type-C και πραγματική έξοδο balanced με βύσματα 4.4mm και 2.5mm. Φοράει δυο τσιπάκια CS43131 και έχει ισχύ εξόδου 120mW/32Ω. Κατάσταση σαν καινούργιο με χρήση λιγότερο από 3 ώρες.
Πληροφορίες και review
Τιμή €45 με δωρεάν αποστολή μέσω Box.
DDHiFi TC44B 2.5mm4.4mm Balanced DAC Amplifier
2.5mm/4.4mm Balanced Audio Adapter The TC44B is designed with two balanced output ports for meet different needs. Both the 2.5mm and 4.4mm are simply plug and play, truly user-friendly. The 4.4mm output port is grounded connected, so it’s more suitable to use with balanced active speaker. Get...
linsoul.de
ddHiFi TC44b - Review
The $89 USD ddHifi TC44b is a tiny DAC/AMP made to replace your phone or PC sound card. It offers both a 2.5mm and 4.4mm Balanced output!
www.headfonia.com
ddHiFi TC44B Review (Headphone Adapter)
This is a review and detailed measurements of the ddHiFi TC44B balanced portable DAC and headphone amplifier. It was kindly sent to me by a member and costs US $90 although I think Drop carried it for $80. The TC44B brings a bit of departure in form factor in its triangular shape: A...
www.audiosciencereview.com
