deck toshiba pc-g55r,2 capstan,3 μοτερ,2 κεφαλες (χ2),dolby b,c,auto reverse play-rec,ic logic,timer
deck toshiba pc- g55 r,made in japan, κατασταση βιτρινας,3 μοτερ,2 κεφαλες (χ2 ) περιστρεφομενες,2 capstan,auto reverse play- rec,ic logic, timer play- rec,direction(one side, two sides, full repeat),index scan, blank scan, auto tape selector, rec arm, dolby b, c,συστημα mqjs, αυτοματη ανιχνευση τραγουδιων,αυτοματη ευρεση κενου σημειου της ταινιας,auto reverse εγγραφη,εξαιρετικος ηχος,τιμη 90 €
type: auto reverse, 2 - head, single compact cassette deck
track system: 4 - track, 2 - channel stereo
tape speed: 4. 75 cm/s
motor: 1 x reel, 1 x capstan, 1 x door
heads: 1 x record/playback, 1 x erase (x2 )
tape type: type i, cro2 , metal
noise reduction: b, c
frequency response: 25 hz to 19 khz (metal tape)
signal to noise ratio: 58 db
wow and flutter: 0. 017 %
total harmonic distortion: 0. 8 %
input: 70 mv (line), 0. 3 mv (mic)
output: 0. 4 v (line)
dimensions: 420 x 110 x 270 mm
weight: 6. 3 kg
finish: silver
year: 1983
Vaslamp
