Denon AVR 3806....
.......μαύρου χρώματος,στο κουτί του με ολά τα παραλκόμενα.
Τεχνικά χαρακτηριστικά
DENON AVR 3806
160 watts x 7 into 6 omhs 1KHZ THD 0,7%
120 watts x 7 into 8 ohms (20-20,000 Hz) at 0.05% THD
Dolby Digital EX, DTS-ES, DTS 96/24, Pro Logic IIx, and DTS Neo:6 processing
1080p-compatible HDMI switching (2 in, 1 out)
analog-to-HDMI video conversion
HDMI version 1.1
XM Satellite Radio Ready (requires XM subscription and optional XM Mini-Tuner package)
Audessey Laboratories' MultEQ XT eight-point auto setup and room calibration system (microphone included)
triple-room/triple-source output:
composite video and preamp-level stereo audio output for 2nd room
fixed line-level stereo audio output for 3rd room
powered stereo audio output option for either 2nd room or 3rd room allows 5.1 home theater in main room
learning/multibrand touchscreen electro-luminescent remote
sixteen Burr-Brown 192kHz/24-bit DACs
ALPHA 24 Plus upsampling for stereo and multichannel digital sources
Denon Link input for digital transfer of stereo or multichannel DVD-Audio and SACD signals from compatible components
Pure Direct modes switch off all unused circuitry for the cleanest possible sound HDCD® decoding
7.1-channel input
7.1-channel preamp output
component video switching: 3 in, 2 out (100MHz bandwidth)
component video conversion (composite to S-video, or composite and S-video to component)
digital inputs: 5 optical, 2 coaxial
2 optical digital outputs
3 audio (including phono) and 7 audio/video (including 7 S-video) inputs on-screen display (requires TV with audio/video input)
DDSC-Digital design isolates each type of digital processing in its own block to preserve the purity of audio and video signals
variable low-pass crossover
high-current, low-impedance amp design
1 set of main speaker outputs
56 AM/FM presets
17-1/8"W x 6-3/4"H x 17-1/2"D
Tιμή 650 ευρώ.
Απάντηση: Denon AVR 3806....
Στα 500 ευρώ η τιμή παιδιά..ακατέβατα πλέον..
Κρίμα να κάθεται..είναι πολύ καλό μηχάνημα..
Νέα και τελική τιμή τιμή πλέον 480 ευρώ..
Τηλ 6947520986 Θανάσης
Ο Ενισχυτής πουλήθηκε.
Ευχαριστώ όλους για το ενδιαφέρον τους.
Η Αγγελία μπορεί να κλείσει..
opanamas
