ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
6-channel digital power amp with total output of 600 watts (plus the 100 watt subwoofer)
* RDS FM plus AM with 40 memory presets (new) and a sleep timer (new)
* Dolby Virtual Speaker for dramatic surround from 2 or 2.1 speakers
* Dolby Headphone for private surround
* 32-bit floating point DSP as used in DENONs high-quality AV separates
* Auto Decode function detects the format from the disc being played and selects the appropriate surround decoder
* 2-channel sources can be played in stereo or in multi-channel via Dolby Pro Logic IIx (new) & DTS Neo:6
* Video Conversion converts composite to to S-Video
* Comprehensive inputs & outputs inc 7.1 rears (new)
* 6ch external input supports SACD, DVD-Audio etc
* Extended 8 Point Subwoofer crossover switching: 40/60/80/100/120/150/250 Hz (new)
* Banana plug speaker terminals for all channels
* 435 (W) x 80 (H) x 380 (D) mm
DVD-550SD Progressive-Scan DVD Video Player - only sold as pair with receiver above
* High performance with PAL Progressive Scan, the latest video decoding and component output
* 10bit/54MHz Video DACs (new)
* 24bit/192kHz audio DACs (new)
* Progressive-scan circuitry, for superior picture quality with plasmas and other prog-scan capable displays
* High-accuracy video decoder, and high-speed, high-accuracy video D/A converter
* CD-R/RW (MP3/WMA/JPEG/Kodak Picture CD) Playback
* 435 (W) x 80 (H) x 360 (D) mm
SYS-550SD 5.1 Speaker System
* Extruded aluminium and wood cabinets with high quality drive units
* Twin Push-Pull bass drivers in satellites and centre
* wideband 90kHz hyper tweeters (new)
* 100 watt subwoofer in slim trapezoid design
* Matched centre & surrounds
* Gold plated Brass Binding posts
