Dynaudio Focus XD
m1ts0s
News poster
http://www.dynaudio.com/focusxd/
"The Danes at Dynaudio go active and fully digital with their new Focus XD range. The initial plan calls for 3 models - the 200XD compact and the floorstanders 400XD and 600XD. Built-in class D power scales from 300 to 450 and 600 watts as these models increase in size. Inputs are 24/192 coax and analog which undergoes A/D conversion inside. Volume control is built in to decommission a separate preamp; and DSP adjustments allow compensation to taste and room. For expanded connectivity there is the Dynaudio Hub with two more analog inputs and digital coax and Toslink. Further details and pricing on the DX range remain TBA."
m1ts0s
News poster
The Focus XD-series is available in Satin Black, Satin White, Rosewood, Walnut.
Satin Black, Walnut and Rosewood come with a black grille.
Satin White comes with a grey grille
Digital input (75 ohm coax)
Analogue input (RCA)
All speakers in the Focus XD-Series are delivered with a built-in IR sensor that makes it easy to control volume with the included aluminium remote. When using the speakers, you have the option of turning off the IR LED.
The speakers work with a pure 24/192 kHz signal, which is run through the DSP and amplified without compression.
You can add the convenience of wireless playback from your audio sources by connecting via the optional Dynaudio Hub.
The Speaker Position EQ control allows the Focus XD loudspeakers to be optimized via DSP equalization for neutral, wall or corner placement in any room.
Focus 200 XD
Each Focus 200 XD incorporates a 300 watt digital amplifier, perfectly optimized to the high-performance woofer and tweeter, allowing them to reproduce sound at the finest level possible.
Focus 400 XD
The Focus 400 XD combines the best of two worlds: The sleek elegance of a compact floor-standing loudspeaker design featuring dual Dynaudio Esotec+ woofers and an Esotec+ soft dome tweeter with the astonishing sonic performance of 450 watts of amplification.
Focus 600 XD
The Focus 600 XD is the flagship Focus XD model and sets the definitive performance standard for high-end digital active loudspeakers.
With a combined power output of 600W per speaker, the 600 XD offers a performance reserve allowing it to realistically reproduce the most demanding large orchestral performances, to faithfully recreate the feeling of a live recording, or to deliver the full impact, energy and depth of modern electronica music.
http://focusxd.dynaudio.com/
XD 200: 5.000 EUR
XD 400: 8.000 EUR
XD 600: 10.000 EUR
Muchas Gracias...:thumbsup:
Μαζί με το...Ζερό της Avantgarde,σηματοδοτούν την απαρχή της καταλληλότερης εποχής γι αναζήτηση νέων ηχείων...
το οτι ειναι "φουλ ντιτζινταλ":D (σχεδον αλα grimm), τελικα, κανει (ηχητικα) τη διαφορά, σε σχεση με αλλα "απλα" ενεργα ηχεια?
γιατι μια μικρη χρηματικη διαφορα σε σχεση με τα "απλα", την εχουν...
m1ts0s
News poster
The 2017 range has had a ground-up revamp of its signal-processing flow (incorporating elements from Dynaudio’s professional LYD range of studio monitors) for substantial improvements in sound quality. Redesigned, re-tuned and more efficient crossovers behave more like digital versions of passive speakers. That simpler internal processing means an even more transparent, even more authentic sound.
The relationship between the digital amplifiers and the drivers has also been optimised, including the overload-limiters: redesigning the signal flow here has resulted in higher volume levels from the drivers without distortion or compression. It also improves signal-to-noise ratios and dynamics and, in the case of the Focus 60 XD, even lower bass.
Less need for complicated crossover filters means there’s more computing horsepower available for speaker-position compensation. That doesn’t mean simply altering the bass – it covers the whole frequency spectrum. The technology adjusts for variances that happen in frequency and phase when placing the speaker near a wall or in a corner. The 2017 Focus XD can now do this at a higher resolution for greater accuracy – and better sound even when speakers can’t be placed optimally in the room.
Also new is the ‘brightness’ control from Dynaudio’s LYD pro-studio range. It adjusts the whole frequency character of the speakers, rather than just the treble. users can set an overall brighter or darker sound to suit their room and preferences.
Roland Hoffmann, Senior Manager, Dynaudio Academy, says: “This is an awesome new tuning – a clear improvement that you’ll hear instantly. The bass is much better defined and more transparent without being lean; treble is smoother without being darker; and there’s a more effortless, airy sound overall. It’s simply on another level.”
The updated Focus XD also comes in five new finishes: satin white lacquer, high-gloss black lacquer, high-gloss rosewood veneer, high-gloss walnut veneer and high-gloss grey oak veneer. The grilles have a new, shorter design that shows more of the speaker’s finish, and their metal parts have also been given a makeover: the driver chassis, front plate and feet are now black instead of silver.
http://www.dynaudio.com/dynaudio-academy/2017/february/dynaudio-launches-updated-focus-xd-at-ise
Και κάτι σημαντικό:
Owners of older Focus XDs can get the improvements, too
All the new speakers use the same hardware platform as the original Focus XD. So, because all the improvements have been made in software form, owners of existing Focus XD speakers will be able to upgrade their firmware through a free update expected to be available in March at www.dynaudio.com/support.
Κι αυτό, κυρίες και κύριοι, είναι ένα έξοχο παράδειγμα εταιρίας η οποία αποδεικνύει εμπράκτως ότι σέβεται τους πελάτες της και δεν τους βλέπει μόνο σαν πορτοφόλια.
Τεστ Focus 600 XD ... είναι του Ιανουαρίου, δε γκζέρω αν ξανα-ποσταρίστηκε:
https://www.computeraudiophile.com/ca/reviews/dynaudio-focus-600-xd-loudspeaker-review/
Εξαιρετική κριτική ηχείων, που οφείλουν όλοι να την διαβάσουν, διότι αποτελεί τζάμπα μάθημα για τον ήχο.
Κανονικά θα έπρεπε να πληρώσεις για να μάθεις αυτά που λέει το παλικάρι στην άνωθεν κριτική..
Κάποιοι από εμάς, αυτά για να τα μάθουμε τα πληρώσαμε με αίμα, με χρήμα και ατέλειωτες ώρες διαβάσματος, κι εδώ είναι τζάμπα, και με λινκς...
Συμπερασματικά, ακόμα κι αν δεν έχετε κανένα απολύτως ενδιαφέρον για το εν λόγω ηχείο:
Κάντε τη χάρη στον εαυτό σας, και μάθετε απ'εξω κι ανακατωτά ο,τι λέει εκεί μέσα, συν τα λινκς. ;)
Και όλα αυτά γιατί;;;;
Γιατί απλά ο άνθρωπος ειναι πρώτα ex-recording/mixing engineer και μετα reviewer.
Οι άλλοι ειναι απλά viewers.
  • loggeo
mrkgeo
