E-mu Systems 0404 White
xfader
Νέα εξωτερική (USB) κάρτα ήχου από την E-MU
με εντυπωσιακά χαρακτηριστικά για την κατηγορία της:
Technical specifications
- Premium 24-bit/192kHz A/D and D/A converters (A/D: 113dB SNR, D/A: 117dB SNR) deliver unmatched USB audio fidelity
- E-MU XTC Class-A ultra-low noise Mic/Line/Hi-Z preamplifiers (-127dB EIN) with 48V phantom power and ground lift switches enable you to plug microphones, keyboards and guitars straight into your computer with professional results, while the built-in analog soft limiting circuit lets you record a hotter signal without fear of clipping
- Comprehensive digital I/O with optical and coaxial S/PDIF (switchable to AES/EBU) and MIDI In/Out to easily connect all of your digital studio gear and instruments
- Ultra-low latency USB 2.0 drivers offer accurate timing and playback of your recorded audio and software instruments
- Hardware zero-latency direct monitoring (mono/stereo) allows you to record and overdub with no annoying delay
- Plug-and-play operation with hands-on control of all major functions like master level, direct monitoring, preamplifier controls and more
- Cross-platform support (Windows XP/x64 and Mac OS X) and compatibility with most popular audio/sequencer applications (Windows: ASIO2, WDM, MME, AC-3 and DTS Passthru; Macintosh: Apple CoreAudio, CoreMIDI, AC-3 and DTS Passthru)
I/O Configuration:
- Two E-MU XTC Ultra-low Noise Mic/Line/Hi-Z Preamps with Soft Limiter and 48V Phantom Power (-127dBu EIN)
- Two 1/4" Balanced Outputs (117dB SNR)
- Stereo 1/8" Speaker Output (117dB SNR)
- 24-bit/96kHz S/PDIF Optical In/Out (Switchable to AES/EBU)*
- 24-bit/96kHz S/PDIF Coaxial In/Out (Switchable to AES/EBU)*
- MIDI Input/Output
- Stereo Headphone Output (114dB SNR)
Τιμή: ~200€
xkaragi
