Event Opal monitor
xfader
Η Event κυκλοφόρησε επιτέλους το πολυαναμενόμενο Opal, που ανήκει στη "hi-end" κατηγορία των studio monitors. :137:
Το EX8 8ιντσο woofer του έχει απόκριση 30 Hz - 10kHz
και μπορεί να "αντέξει" έως 1000 Watt peak power.
Περισσότερα χαρακτηριστικά:
Technical specifications
* Variable Impedance Flared Ports (patent pending)
* Eliminates artifacts heard in rear reflection ports that rely on room acoustics
* Internal engineering removes all port noise
* Cabinet designed with complex radii to eliminate diffraction
* Complete aluminum construction provides low resonance and pure wide sound stage
* EBT1 Tweeter with powerful neodymium motor
* Rotatable high frequency wave guide for side mounting
* 750 Watts Peak Power
* Microphone for room analysis and optimum configuration
* 8" EX8 Driver with 30Hz to 10kHz raw response
* Carbon fiber reinforced cone with 63mm neodymium motor
* Second dedicated voice coil
* Linearized impedance and reduced inductance
* Dramatically lowered distortion characteristics
* Increased speed and control of cone assembly
Τιμή: 3.000 δολάρια το ζεύγος.
http://eventelectronics.com/
JAndronikos
