Fairland Studio
m1ts0s
News poster
FAIRLAND V2
19.960,00 EUR (ζεύγος)
  • 3 way active
  • Frequency range (-6dB) 30Hz – 20kHz
  • HF/MF: 150mm AMT Tweeter, d’appolito layout 2 x 6“ midrange driver
  • LF: 12“ driver
  • MAX SPL [dB] – ≈120 Total
  • Output Power (DSP-AMP-Modul): 1000W
  • Dimensions (H x W x D): 126 x 71,5 x 44 cm – (without feet/spikes)
  • Weight: ≈ 94kg
  • Limiters (Look ahead peak limiter, thermal limiter, overall power supply limiter)
  • Crossovers (Bessel, Butterworth, Linkwitz-Riley, Critical)
  • Other DSP features (input delay, output delay, phase inversion, gain)
  • FIR (Linear phase X-over and linear phase loudspeaker equalization)
  • IIR (Low-/Highpass 6 and 12 dB, Bell filter, allpass, shelving filter 6 dB and 12 dB)
FAIRLAND C6
13.780,00 EUR (ζεύγος)
  • 3 way active
  • Frequency range (-6dB) 27Hz – 20kHz
  • HF/MF: coax – 1“ compression driver, 6“ driver
  • LF: 12“ driver
  • MAX SPL [dB] – ≈115
  • Total Output Power (DSP-AMP-Modul): 1000W
  • Dimensions (H x W x D): 106,2 x 44 x 53 cm – (without feet/spikes)
  • Weight: ≈ 73kg
https://www.fairland-studio.com/fairland-hifi-lautsprecher
who7
