Ενεργό sub από την Focal Professional με 11ιντσο κώνο από Polyglass® και 300W RMS ενισχυτή.
Τεχνικά χαρακτηριστικά:
ΤΙΜΗ : ~700€
Link εταιρείαςFrequency response (+/-3dB) : 30Hz - 250Hz
Maximum SPL : 113dB SPL (peak @ 1 m)
Input :
Left, Right, LFE
Electronically balanced / 10kOhms
Female 3 pins XLR
Variable
Output :
Left, Right
Male 3 pins XLR in parallel on inputs
HF amplifier stage : 300W rms, BASH® technology
Electric supply :
230V (T1.6AL fuse rating) or 115V (T3.15AL fuse rating)
IEC inlet and detachable power cord
Adjustment :
Sub level (sensitivity) adjustment
Lo-pass frequency adjustment
Phase adjustment
Polarity switch
Mute
External Mute (controlled by external footswitch)
Indicators :
Power on
Mute
External Mute
Transducers : Polyglass, high excursion Focal, 270mm (11") drive unit
Construction : 22mm MDF panels with internal braces
Finish :
Dark grey vinyl
Dimensions with spikes : 435.5mm x 366mm x 440mm (17.1" x 14.4"x 17.3")
Net weight : 23kg (50.7lb)
ΤΙΜΗ : ~700€
