m1ts0s
News poster
This loudspeaker achieves a level of quality that eludes conventional passive speaker concepts. The Neo from genuin audio is consistently based on active technology in combination with highly complex digital signal processing. Therefore the chassis used are ideally fitted, optimally driven and perfectly controlled. The uncompromising realization of this technical concept in Neo leads to an extremely dynamic, transparent and natural music reproduction.
Perfect control through DSP
The heart of the fully active 3-way speaker is a digital signal processor. The 32-bit DSP not only replaces a passive crossover and allocates woofer, midrange and tweeter to their respective operating range but the entire speaker system is perfectly in tune with its time coherence and frequency response. In addition to an IIR filtering, notably the technology of performance-data-based linear-phase FIR filtering is used, which Neo’s renowned developer team has successively optimized since the 80s.
Every single chassis is tested, and based on these individual test results, tailored programming is carried out for perfect signal processing. In this way, the temporal behavior of the overall system can be so designed that the propagation speed of all frequency components in the music signal is constant. This time-coherence is an essential feature to achieve genuin audio’s central goal of a convincingly authentic music reproduction.
Amplitude frequency response (blue): The entire audio spectrum is shown with extremely low ripple. The -6dB cutoff frequency is 27Hz.
Phase response (green): The linear progression of the phase over the almost entire frequency range (60-20kHz) is the result of linear-phase FIR equalization. The slope of the phase is a measure of the group delay and the criterion for the dispersion of one frequency group (pulse signal).
Construction principle 3-Way Digitally controlled active speaker
DSP 32 Bit Linear phase FIR-filterdesign
Amplifier 4-channel UMAC®-Class D-module
Power max. 1.000 watts
Operation control Touch Display
AD and DA Converter bit depth 24 bit
AD Converter dynamic range 128 dB
Input analogue 1 x XLR balanced
Input digital 1 x XLR AES/EBU
Pre-Sets 3: Neutral, Wanll, HiFi
Driver mid/high frequency coaxial (6,5″ midrange/1″ tweeter)
Driver low frequency woofer (12″) with long excursion, 3″-voice-coil and triple aluminium demodulation rings
Crossover frequency 180 Hz / 2000 Hz + 20 Hz High pass
Spikes Height adjustable
Cabinet MDF (19-54 mm) veneer or high gloss lacquer surface black or white (special colours on request)
Size 112,2 cm x 25,7 cm x 48,5 cm (without spikes)
Weight 47 Kg
Special Feature Digital room correction
https://www.genuin-audio.de/en/produkte/neo/
