Goertz balanced power units
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Αντιγράφω από δελτίο τύπου της εταιρίας
Alpha-Core's Goertz line of products had added three new, attractively-priced balanced power units. The 300VA, 600VA, and 1000VA ($285, $355 and $433 respectively) help reduce or eliminate hum and noise from electricity by balancing the positive and neutral sides. This technique has been praised for many years by professional recording studios, reviewers, and consumers. Goertz's products consist if a transformer potted in epoxy compound inside a round steel enclosure with an outside finish of scratch-resistant, off-white powder coated enamel. The Goertz Power System has a two-foot long power cord for each of the input and output. Outside diameter of the housing ranges from 5.1-inch diameter for the 300VA, 6.7-inch for the 600VA, and 8.25 for the 1000VA with weight being is 8 lbs, 13 lbs and 20 lbs respectively. A bracket for wall mounting is included, though the unit can also be installed on an equipment rack.
Christos Kourmouzoglou
