![](/forum/proxy.php?image=http%3A%2F%2Fwww.gryphon-audio.dk%2Fimages%2Fproducts%2Fsonataallegro%2Fmain.jpg&hash=1e4efaee2aa2bbebbaf958448a92f7d7)
![](/forum/proxy.php?image=http%3A%2F%2Fwww.gryphon-audio.dk%2Fimages%2Fproducts%2Fsonataallegro%2F2.jpg&hash=7d547a5db11957506f1f7745445ef561)
![](/forum/proxy.php?image=http%3A%2F%2Fwww.gryphon-audio.dk%2Fimages%2Fproducts%2Fsonataallegro%2F1.jpg&hash=d0816767012e5b01975dbf75f0baba6f)
True Dual Mono configuration
Infrared remote control
Fully discrete circuitry
Pure Class A operation
Microprocessor-controlled menu functions
Ultra-wide frequency bandwidth
Zero negative feedback
Select premium-grade components
Microprocessor-controlled passive resistor volume control
Custom-built C-core transformers
33,000 microFarad capacity per channel
DC-coupling with servo-control
Isolated power supply for non-audio circuits
Extensive mechanical decoupling
Ultra-short signal path with minimal internal wiring
Non-magnetic, non-resonant aluminum cover
Fully sealed, double-sided mil-spec PC boards with 75 ΅m copper traces
PCB-mounted sockets eliminate wiring and shorten signal path
Gold-plated input-isolating relays
4 balanced inputs and 2 balanced outputs with PCB-mounted gold-plated Swiss Neutrik XLR sockets
2 single-ended inputs and 1 single-ended output with gold-plated custom phono sockets
Power line conditioning and voltage regulation
Optional Gryphon Legato phonostage module
Designed and built in Denmark
