ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
GENERAL
-Time Coherent
-Dispersion Coherent
-Frequency Response: 23hz to 23,000hz +/-2db
-Nominal Impedance: 6 Ohms
-Sensitivity: 87DB
-True Dynamic
-Tonal Accurate
CABINET
-Engineered, designed, and manufactured by Hansen Audio
-Hansen Audio "CLOAKING DEVICE"
-"Hansen Composite Matrix" material - hybrid design with Class "A" finish
-Acoustically inert
-Sound wave refraction distortion elimination technology TWEETER
-Engineered, designed and manufactured for Hansen Audio
-25mm high performance dome mounted on a dispersion optimized 6mm aluminum plate
-Precision assembled
CROSSOVER
-Engineered, designed and manufactured by Hansen Audio
-V2 DAT (Driver Assimilation Technology)
-Frequency and phase optimized
-Hand assembled
-High grade hand selected components
-Point to point silver solder connections MID BAND DRIVERS
-182 mm driver
-Exotic multi-layer composite sandwich cone
-Optimized geometry "Hansen" motor system
-Hand assembled "Hansen Architecture" frames
-Sound wave deformation prevention
TERMINAL CONNECTIONS
-High current pole terminal
-Decreased transition resistance WOOFERS
-269 mm driver
WEIGHT 270 lbs. with crate
SIZE
-Height: 42 inches
-Width: 14 inches
-Depth: 20 inches
39.000$
http://www.hansenaudio.com/prprince.htm
http://crave.cnet.com/8301-1_105-9875111-1.html
