Harmonic Resolution Systems
Harmonic Resolution Systems develops isolation and damping products that significantly reduce structure-borne and air-borne vibration over the entire frequency range of any audio/video system. Many years of engineering experience, custom material development, and listening tests have resulted in a product line that enables your audio/video source and amplification components to achieve peak performance.
HRS develops and manufactures products of exceptional performance and quality. Our products create an environment that produces a significant increase in signal quality. The reduction of harmful vibration is obtained on a wide range of audio component designs and construction techniques thus making HRS products insensitive to normal variation in product design and system location.
Audio system benefits include:
· Drop in the noise floor reveals a new base level of inner detail
· Eliminates glare in digital signal quality without sacrificing resolution
· Improves bass frequency response and resolution
· Larger soundstage with increased space between instruments
· Increases detail and resolution of analog and digital source
· Significant increase in system musicality and performance veracity
ΜΕΡΙΚΑ ΠΡΟΪΟΝΤΑ:
M3 Isolation Bases
Equipment Racks
Analog Disk
The Analog Disk significantly reduces the negative impact of air-borne and structure-borne vibration on your turntable performance. The Analog Disk should be placed directly on the record with the soft side (a custom formulated elastomer) in contact with the record label and turntable spindle. It is 3.25" (8.25 cm) in diameter and 1.35" (3.43 cm) in height and 315 grams in weight. The Analog Disk is produced with a black anodized aluminum finish.
Starting MSRP $110.
xkaragi
