HDMI cable
Πωλείται HDMI καλώδιο της ΗΑΜΑ 10μ,καινούριο, λόγω υπερβολικά μεγάλου μεγέθους για το χώρο,που προοριζόταν, μόνο 70€. Η αρχική του τιμή είναι 160€, επομένως είναι ευκαιρία!!
- Professional connection cable for digital video signals and data
- Developed for sophisticated professional and home cinema applications
- Precious cable material and particularly adjusted plug components, perfectly adjusted and developed with the requirements in accordance with the HDMI specification
- Optimal data flow by silver-plated leads for the reduction of digital jitter.
- 24K-gold-plated contact surfaces for outstanding and long-lasting reliability of electrical contacts without transition resistance
- Exactly matching plugs for optimal plug-in, with perfect seat and easy handling
- Separately shielded data lines diminish the cross modulation between the data lines
- Colour: black
- HDTV suitable
- Packed in blister
Technical Details
Connection A
HDMI plug, 19-pin
Connection B
HDMI plug, 19-polig
Colour
Black
HDTV suitable
yes
Use of cable
Connecting
Length
10,0 m
Length range
10 - 19,9 m
Quality
3 Stars
Type
HDMI - HDMI
George Martini
