HDTV ... σας (ξανα)παρουσιάζω την TwinhanDTV Sat-CI
panosop
Συστημικός
Μόλις έβαλα την τελευταία έκδοση λογισμικού την 2.603 beta, και ΕΚΠΛΗΞΗ...
είδα το EURO1080
το παράξενο είναι ότι πουθενα δεν αναφέρει ότι κάνει αποκωδικοποίηση HD....
θα σας παραθέσω και φώτο μόλις τις ανεβάσω, για του λόγου το αληθές...
Στοιχεία απο αυτή την κάρτα είναι τα εξής...
Key Features
• High quality digital satellite TV & radio receiving (DVB-S)
• Designed-in common interface for pay TV receiving --You need extra CAM & subscribed smart card for
pay channel reception
• High speed Internet via satellite -- You need to apply an Internet ISP account first
• DVB data service
• Instant recording -- Record digitally as MPEG II format. 1 hour digital TV program is about 1.7G
• Schedule recording -- You can set your own recording list and playback whenever you like
• Time-shifting -- You can pause live TV shows and never miss any marvelous moment!
• Electronic program guide (EPG) -- EPG tables offer the most updated channel information
• Teletext -- Teletext page is only available in certain areas
• Still frame capture
• Multi channel preview matrix
• Support DiSEqC1.2 & USALS
• Transponder & satellite auto scan
• 16:9 wide screen
• Multi-language output
• Hot Keys
• Favorite list
• Video quality adjustment
• MPEG II software decoding
• Software upgradeable
• Support remote control
Specification
Tuner • Input terminal: F-type 75 Ohm
• Receiving frequency: 950~2150MHz tuning range
• Input level: -65~25dbm
• Support MCPC and SCPC
QPSK & FEC • Symbol rate: 2~45Msps
• QPSK filter: Root-raised cosine filter with roll-off 0.35
• FEC: 1/2, 2/3, 3/4, 5/6, 7/8 and Auto
LNB & Switch control • LNB supply voltage:13 or 18V
• DiSEqC:1.2
• Support Data Burst & Tone Burst
• Antenna and LNB control: 22KHz tone
• Max. LNB supply current: 400MA with short circuit and surge protection
PCI interface • PCI bus: PCI 2.2 compliant
• Host bus burst rate: 132MB/s
• Host bus width: 32 bit
Demultiplexing • Max. No. Section filtering:32 PIDs
• Engine: software
• Descrambler: DVB descrambler(Common Interface)
• Streams capture: PES and TS
A/V Format • Video format: MPEG-II Main Profile& Main Level
• Audio format: MPEG-II Audio layer I & II
Compatible CAMs (Conditional Access Module)
Irdeto 1.06
Seca 1.05
Viacess 1.0 V481/V483
AlphaCrypt 1.0
BataCrypt 1.0
Conax 4.0/4.00e
Cryptoworks 1.0/12011
Aston Crypt 1.03/1.05
Nagravision ALL
παλαιότερα ξαναπαρουσιάστηκε αυτή η κάρτα ΕΔΩ
oikapo
