HECO Statement
Κώστας Φ.
High end German audio manufacturer, Heco has introduced its new flagship floor-standing loudspeaker dubbed the Statement.
The Statement includes a carbon coated 1” tweeter, a 6.5” paper cone midrange, a pair of 8” paper cone woofers and a trio of rear firing port tubes. The drivers are also housed in a hexagonal MDF enclosure that isolates the midrange and bass drivers to reduce interference. With this driver setup, the Statement is capable of handling 500 watts of power at 4 or 8 ohms while delivering a frequency range of 18-50,000 Hz.
The Heco Statement is available now in either gloss black or silver for about $6,000 a pair.
audiojunkies.com
Κώστας Φ.
German speaker company Heco is launching a new floorstanding design, the £3000-a-pair Statement.
The speakers combine a hexagonal cabinet profile with advanced driver design and layout, stand 1.23m tall and weigh 43kg apiece, and claim bass extension all the way down to 18Hz from their twin 20cm bass drivers.
The three-way speakers have triwirable terminals allowing adjustment of the midrange and treble levels, and are suitable for use with amps of between 30W and 500W.
The 25mm soft-dome tweeter, coated with carbon particles, sits below the 16.5cm midrange driver, which uses a paper cone and sits in its own open-backed compartment, allowing it to operate without compression.
The two paper-cone bass drivers are in their own enclosure, reflex-loaded with no fewer than three rear-venting port tubes, and the speaker is available in high-gloss black or silver.
whathifi.com
Ε τώρα, αυτή η επανάληψη του λογότυπου σε κάθε μεγάφωνο... Κάτι σαν την ελληνική επαρχία ένα πράμα...
melina
Cargo 200
Τελικά 3000 ή 6000 ντόλαρς στοιχίζουν.
Οπως και να'χει για να βγει το hi end σε αυτή τη χαμηλή τιμή, πρέπει να κρατήσουν το ίδιο καλούπι, όπερ και η επανάληψη του Logo!
Κώστας Φ.
$6000, £3000
:cool_4:
melina
Cargo 200
α είχε και πάουντς, κουιντς, πως το λένε, σόρρυ.
Εκεί έχει παέι η ισοτιμία USD/GBP?
Manosmathiou
