Από την Ουγγαρία. Πριν λεγόταν ZSOLT AUDIO
Heed Audio LUNA
Preamplifier with R/C
Technical specifications
Input sensitivity/impedance: 250 mV/10 kOhm
Output voltage/impedance: 0.775 mV/10 Ohm
Gain: 10 dB
Signal/noise ratio (unweighted): 100 dB
Headroom 26 dB
Frequency range (with filter): 5 Hz-50 kHz (±0,5 dB)
Heed Audio CANOPUS
Mono Power Amplifier
The CANOPUS is a 3-stage, Class-AB mono power amp design, using fully discrete components. Its power supply consists of a 100 VA torodial transformer and two 10,000 ΅F capacitors, manufactured by BHC to Heed's own specifications, whilst its output stage is built with complementary Darlington, 25 A power transistors. Due to its balanced circuit topology, the CANOPUS is barely susceptible to external interference. Its input sensitivity and impedance enable the user to connect the CANOPUS directly to a CD-player or one of our phono stages.
Input sensitivity/impedance: 600 mV/10 kOhm
Power output (continuous, 20Hz-20kHz): 35/50 W (8/4 Ohm)
Signal/noise ratio (unweighted): 96 dB
Distortion (THD, 1kHz, 1W, 8 Ohm): 0,06%
Frequency range (with filter): 4 Hz-60 kHz (±1 dB)
Heed Audio QUASAR MM/MC Phono Stage
MM input: 3 mV /47 kOhm / 100 pF
MC input: adjustable
Sensitivity: 100 ΅V - 220 ΅V - 600 ΅V
Impedance: 100 Ohm / 220 Ohm / 470 Ohm
Output voltage:
"Low Out": 220 mV/100 Ohm
"High Out": 775 mV (0 dBm)/ 22 Ohm
Heed Audio Ltd.
PO Box: 45
H-1676 Budapest
Hungary
eMail: [email protected]
Heed Audio LUNA
Gain: 10 dB
Headroom 26 dB
Heed Audio CANOPUS
Output voltage:
Heed Audio Ltd.
PO Box: 45
H-1676 Budapest
Hungary
