HGP loudspeakers
HGP LYRA SoNova
The Design
Type 2 1/2 way, dipol, 6drivers
SoNova-Technology
double-chamber resonance system
Drivers 2 pcsTextile-Tweeter 25mm
Fronttweeter: SoNova, Reartweeter SuperTech
13cm-mid-cone KEVLAR/CARBON
1x17cm-bass-cone KEVLAR/CERAMICS
2x21cm-bass-cones KEVLAR/CERAMICS / TwinTech - system
Principle of operation 25-25,000 Hz, 92dB, 6ohms
Dimensions (HxWxD) 123,5x21,0/25,0x40,0 [cm]
1983 Line Source
The Design
Design 2 1/2 way floorstanding speaker, crossover at 150/4000 Hz
Drivers TTweeter, pure silk, 25mm (3500 Hz and up)
Midrange drivers: 2 pcs, Kevlar/Carbon fibre, 13cm, (120-4000Hz)
Woofers: 4 pcs, Kevlar/Carbon fibre, 13cm, (up to 120Hz)
Cabinet system Woofers: Dual-Chamber Resonance System, Line Source (4 Woofers with 16 ohms in parallel connection)
Frequency Response 35 - 30.000 Hz (0/-3dB)
Sensitivity 91 dB for 1W at 1m
Impedance 8 Ohm, minimum at 4,5 Ohm
Amplifier Requirements 10-150 Watt/s
Dimensions H x B x T: 110 x 16 x 33
Weight 34 Kg / pc
Finish all available real wood veneers and paint (on request)
Βασίλειος
