Βγάζουμε μια οθόνη σε τρίποδο, τον βιντεοπροβολέα σε τραπεζάκι κήπου και ένα φθηνό ενισχυτή 5.1 με ενσωματομένο DVDp
Kαι για ηχεία έχουμε σταθερά στον κήπο αυτές τις "πέτρες":
να και τα χαρακτηριστικά τους:
820Rox
Features:
8" Polypropylene Cone Woofer with Sealed Voice Coil and Silicone Encased Leads
1/2" Polyamide Dome Tweeter with Silicone Encased Leads, Coaxial Mounted
Similar in Sound to the 8.1CRS
Available in Sandstone, Granite Grey and Brown Clay.
Specifications:
Efficiency: 90dB 1W/1m
Power Recommendations: 5 - 100 watts (undistorted)
Impedance: 8 OHMS
Frequency Response: 35Hz - 20kHz ±3dB
Dimensions: H 10-3/4" x W 20" x D 19"
ή αυτά:
και να οι προδιαγραφές τους:
620Rox
Features:
6-1/2" Polypropylene Cone Woofer with Sealed Voice Coil and Silicone Encased Leads
Similar in Sound to the 6.1CRS
Specifications:
Efficiency: 91dB 1W/1m
Power Recommendations: 5 - 60 watts (undistorted)
Impedance: 8 OHMS
Frequency Response: 40Hz - 20kHz ±3dB
Dimensions: H 9-1/4" x W 16" x D 14-3/4"
ή αυτά........
520Rox
Features:
5-1/4" Polypropylene Cone Woofer with Sealed Voice Coil and Silicone Encased Leads
Similar in Sound to the 5.2R
Specifications:
Power Recommendations: 5 - 50 watts (undistorted)
Impedance: 8 OHMS
Frequency Response: 55Hz - 20kHz ±3dB
Dimensions: H 8" x W 93/4" x D 63/4"
Kαι τέλος αυτά............
600RoxDT
Features:
Single rock plays stereo sound from one speaker
Two 1/2" Polyamide Dome Tweeters with Silicone Encased Leads, Coaxial Mounted
Similar in Sound to the 6.1DT
Specifications:
Impedance: 8 OHMS
Frequency Response: 60Hz - 20kHz ±2dB
Πως σας φαίνονται? :roll: :roll: :roll:
Δείτε και μια εικόνα που είναι τοποθετημένα στον χώρο!
(κοιτάξτε δεξιά στο συντριβάνι, χαμηλά!) :shock:
Για περισσότερες λεπτομέρειες:
http://www.speakercraft.com/
820Rox
Features:
Specifications:
Impedance: 8 OHMS
ή αυτά:
620Rox
Features:
Specifications:
Impedance: 8 OHMS
ή αυτά........
520Rox
Features:
Specifications:
Impedance: 8 OHMS
600RoxDT
Features:
Specifications:
Impedance: 8 OHMS
