HP 707 digital camera + extras
V
VIDEOMIX
Πωλείται φωτογραφική μηχανή HP, μοντέλο 707, ελλαχιστώτατα μεταχειρισμένη, με θήκη μεταφοράς, ταχυφορτιστή εκτός δηλαδή απο αυτόν της συσκευασίας, δεύτερη ολοκαίνουργια μπαταρία και κάρτα μνήμης 256 mb!!!
Τιμή, μόλις 179 ευρό.
Xαρακτηριστικά.
Image Sensor Type CCD •
Resolution 5.36 Megapixel •
Optical Zoom 3x •
Camera Type Standard Point and Shoot •
Lens
Interchangeable Lens Without Interchangeable Lens •
Optical Zoom 3x •
35mm Zoom Lens 39 - 117 mm •
Digital Zoom 8x •
Focus Type Autofocus & Manual Focus •
Focus Range 20 in. to Infinity (w) / 28 in. to Infinity (t) •
Macro Focus Range 6 - 35 in. (w) / 20 - 39 in. (t) •
Focal Length 8 - 24 mm •
Image Quality
Camera Resolution 5.36 Megapixel •
Image Resolutions 640 x 480 •
Video
Video Resolutions 320 x 240 (QVGA) •
Video Speed 30 fps •
Max Movie Length Without Limit (Depends on the camera free memory size) •
Video Format MPEG •
Exposure Control
ISO Speeds Auto • 100 • 200 • 400 •
Aperture Range f4.8/f8.4 (w/t) - f2.8/f4.9 (w/t) •
Shutter Speed 16 - 1/2000 sec •
White Balance Auto • Manual • Daylight / Sunny (Preset) • Fluorescent (Preset) • Tungsten (Preset) • Shade (Preset) •
Frames Per Second 3 Frames •
Storage
Memory Type Built-in • MMC Card • SD Card •
Built-in Memory Size 32 MB •
Compression Modes Fine • SuperFine • Normal • Basic •
Compression Type JPEG •
File Size (High Res.) 2.5 MB (51 images on 128MB card) •
File Size (Low Res.) .15 MB (about 853 images on 128MB card)
Flash
Flash Type Built-In •
Flash Functions Flash Off • Auto Flash • Fill-in Flash • Red-eye Reduction Flash • Slow Sync •
Viewfinder / Display
Viewfinder Optical •
LCD Panel With LCD Panel •
LCD Panel Size 1.5 in. •
LCD Screen Resolution 119,548 pixels •
LCD Protected Position Without LCD Protected Position •
Interfaces
Interface Type USB • USB 2.0 •
Video Interface Video Out •
Power Supply
Battery Type Proprietary Lithium •
Included Features
Self Timer 10 Sec. •
Mp3 Built In •
Built-in Microphone With Built-in Microphone •
Built-in Speaker With Built-in Speaker •
Tripod Mount With Tripod Mount •
System Requirements
Operating System Apple Mac OS 9 • Apple Mac OS X • Microsoft Windows 2000 • Microsoft Windows 98 • Microsoft Windows 98SE • Microsoft Windows ME • Microsoft Windows XP Home Edition • Microsoft Windows XP Professional •
Dimensions
Width 3.88 in. •
Depth 1.39 in. •
Height 2.36 in. •
Weight 0.4 lb. •
NikosTs
