http://www.cybertheater.com/volent-paragon-vl-4-reflex-port-loudspeaker-system/
vlasis
Φωτογράφος!
When your heart desires to enter into pure music, Paragon VL-4 is your perfect choice. Volent Paragon features 12″woofer equipped with Nomex Hexcone to deliver the highest dynamic bass. Constructed from Kelver and Nomex material, the woofer cone assures fastest impulse response. The Paragon VL-4 reflex port loudspeaker system offers a frequency of 20Hz to 100Hz with excellent dynamic and detailed resolution. Adding to the glorious specs are the Volent’s Patented Twin-Ribbon super tweeter and Air Motion Transducer. The 7-inch sandwich cone drive unit gives unparalleled midrange.
Features
* Frequency Response: 20 Hz ~ 100,000 Hz
* Power Handling: 350W(RMS)
* Sensitivity: 88 dB (2.83/1M)
* Impedance: 8 Ohm (min: 5 Ohm)
* Crossover Point: 230, 1,100 , 5,800 Hertz
* Dimension: 409 (W) x 1202(H) x 725(D) mm
* Weight: 150Kg (net weight per pcs)
Tasos Tsekouras
