HXOΣΥΣΤΗΜΑ
SONY STR-DE875
Number of Channels 5.1 Channels
Stereo Mode Power 100 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.09%
Surround Mode Power 100 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.09%
Surround Sound Dolby Digital� • DTS� • Dolby Pro Logic II
DSP
DSP Processor Type(s) 32 bit Processor x 1
DSP Modes Arena • Church • Cinema Studio EX A-C • Concert • Disco • Game • Headphone Theater • Jazz • Live • Mono Movie • Movie • Night Theater • Opera House • Semi C.Studio EX A-C • Stadium • Virtual
Speaker Impedance 4 Ohm • 6 Ohm • 8 Ohm • 16 Ohm
150ευρω
B&W DM600 S3
Impedance: 8Ω (minimum 3.0Ω)
Dimensions: H 286mm W 175mm D 219mm
H 11.3” W 6.9” D 8.6”
Weight: 4 kg / 8.8 lbs.
Description: 2-way vented-box system
Frequency range (-6dB): 55Hz and 42kHz
Power handling: 100W into 8Ω
Sensitivity: 88dB spl (2.83V, 1m)
150ευρω
Sony sa-wm20 active subwoofer
Type
Active Subwoofer (magnetically shielded design)
Speaker unit
Woofer: 20 cm dia. (8 in.), cone type
Amplifier section
Continuous RMS output :
Canadian model (0.8%) 50W
European model (DIN) 50 W
Other models (0.8%) 50 W
Reproduction frequency range
28 Hz – 200 Hz
High frequency cut-off frequency
50 Hz – 200 Hz
Phase selector
NORMAL, REVERSE
50ευρω
http://aycu18.webshots.com/image/36977/2004345044509281029_rs.jpg
JAndronikos
