I2S over Ethernet...
Κώστας Φ.
Έρχονται ωραία πράγματα... :happy_6:
Attero Tech CobraNet CO²
The Attero Tech CobraNet CO² (Cost Optimized 2nd generation) is a low cost evaluation platform for the Cirrus Logic CS496112 CobraNet Networked Digital Audio Processor + DSP. The CobraNet CO² is a complete CobraNet implementation, including analog stereo inputs and outputs, that shows the ease of providing networked audio with CobraNet and the low component cost with which a CobraNet node can be implemented.
  • Uses the Cirrus Logic CS496112 to support CobraNet networking and user DSP 24-bit stereo A/D converter (Cirrus Logic CS5341) and stereo D/A converter (Cirrus Logic CS4334)
  • Both 1/8" stereo mini-jacks and RCA connectors on inputs and outputs
  • DB-9 connector for RS-232 serial bridge support
  • Supports the Cirrus Logic DSP Conductor software, which allows advanced digital signal processing on the 120 MIPS user DSP in the CS496112
  • Stand-alone mode (i.e. no switch or PC required) routes audio from one CobraNet CO² board to the other. The PC controlled mode, with the supplied software and a switch (not included), allows simple routing to be done
Click
James.z.2007
