iBASSO DX100 HIGH DEFINITION AUDIO PLAYER
Πωλείται το iBasso DX100 Player σε άριστη κατάσταση και λειτουργκότητα. Παίζει τα flac, wav, lp PCM μέχρι 192Khz 24bit. Εχει έξοδο για ακουστικά, Line out, WiFi, κλπ. Συνοδευεται από τον φορτιστη-τροφοδοτικο,
Τιμή: 250 ευρω
Product description
Main Features: - Android2.3 OS With Custom Audio Player Software - Support up to 24Bit/192kHz Bit for Bit Decoding - ES9018 32Bit DAC Chip - Built-in +/-8.5V Headphone AMP - 3.75" Capacitive Touch Screen - Up to 24Bit/192 Optical/Mini Coaxial Output - 3.5mm Headphone Output, 6.3mm Headphone Output, and Line Out - 256-Steps Digital Volume Control - 64G Onboard Flash - Support up to 32G External MicroSD - 3-Setting Gain Switch - SRC Function - Slow Roll-off/ Sharp Roll-off Digital Filter - Support Wifi, Bluetooth - Solid Case Made of Magnesium Alloy and Aluminum Alloy - Audio Formats Supported: APE, FLAC, WAV, WMA, AAC, ALAC, OGG, MP3 - Come With Micro USB Cable, Coaxial Cable, and AC Adapter - One Year Warranty BY Hongkong Authorized official customer service   Specification: Power Source:Built-in 2000mAh 8.4V Li-polymer Battery pack or external power supply Frequency Response: 20Hz-20KHz +0.1/-0.25dB Signal to Noise Ratio:-116dB Crosstalk: 1KHz0dB > -100dB, 20KHz odB = -82dB THD+N: 0.002% IMD: 0.0034% Gain and Output Power: 0dB=2V rms (125mW/32ohm) +3dB = 2.8V rms (245mW/32ohm) +8.5dB = 5.0V rms (83mW/300ohm) Battery Life: 72Hours (stand-by) or 7Hours (play music) Battery Charge Time: 4Hours External Power supply: 12V DC Recommended Headphone Impedance: 8~600Ω Dimension: 2.83W x 4.65L x 0.93H (inch) 71.8W x 118L x 27.5H (mm) Weight: 265g or 9.3oz
Alesta
