iFi xCAN Portable Balanced Amplifier
Στο κουτί του με χαρτία και πλήρη παρελκόμενα.
Χρησιμοποιήθηκε συνολικά 4 φορές σε ταξίδια και δοκιμές με ακουστικά Studio 250 Ohm.
Dual Mono και Balanced κατασκευή.
Από τα πιο δυνατά της αγοράς (αν όχι το δυνατότερο σε ισχύ).
Τιμή 200 ευρώ. - ΠΜς που αφορούν παζάρια ή ανταλλαγές, δε λαμβάνουν απάντηση.
Μείωση τιμής επί του συνόλου, αν αγοραστεί πακέτο με τα Audeze iSine 20 που έχω σε άλλη αγγελία.
The unit boasts a dual-mono headphone amplifier with 1000mW of power per channel which can unleash the full potential of both 32ohm through to 600ohm headphones. It offers balanced in/out to take full advantage of the growing availability of balanced sources and headphones. The 2.5mm balanced headphone jack means the it can be used to boost the amplification of high-end DAPs.
The last word in portable amplifiers
The xCAN is a portable amplifier above all else and is for anyone who wants to squeeze every last drop of performance out of their expensive headphones.
Using a high-end DAP that has an adequate onboard DAC but lacks power? Happy with your existing source but need more juice?
Just add the xCAN to drive bigger and better headphones and boost your tunes.
Blinding Bluetooth
The xCAN delivers CD-Quality Bluetooth via AAC, aptX and aptX LL with added iFi magic.
Stream wirelessly from your smartphone. Bluetooth from your TV to the xCAN. No need for wires. Just plug your headphones into the xCAN at your side.
Give soundtracks extra energy. Add oomph to your gaming! Hear the whoosh of an arrow or the full throttle of F1 car in all their glory.
Wicked wiring
Connect via analogue 2.5/3.5 connection. iFi’s exclusive S-Balanced technology means that you gain the advantages of a balanced connection even when using an unbalanced one.
On headphones this means lower distortion, less interference and less crosstalk.
And it enables you to take advantage of the growing number of balanced sources, such as high-end DAPs.
A pure power house
The xCAN is a dual-mono headphone amplifier with 1000mW of power per channel. It will happily drive your favourite headphones.
And we added our signature sonic extras as well.
3D+® opens up your music to give you the spaciousness of a live-concert atmosphere.
The XBass Ⅱ® analogue bass correction system corrects headphone/speaker bass response to deliver a more natural sound to the midrange frequencies.
Τιμή πώλησης 180 ΕΥΡΩ - Παρακαλώ σεβαστείτε το χρόνο σας και το χρόνο μου.
*Δεν ισχύει πλέον η συνδυαστική μείωση για αγορά μαζί με τα Audeze iSine 20 (οι τιμές μειώθηκαν ξεχωριστά).
Τελευταία τιμή για να φύγει μέσα στο ΣΚ (28/10-29/10) - 145 ευρώ.
Μετά το πέρας της 29/10, η τιμή δεν ισχύει πλέον και η αγγελία αποσύρεται οριστικά.
Λήξη ισχύος της τιμής της αγγελίας.
Παρακαλώ να κλείσει.
Ευχαριστώ για τη φιλοξενία.
Up
Τιμή πώλησης, στα 145 ευρώ.
Τιμή καινούριου στο skroutz: 349 ευρώ.
    Safety Last * tl;dr *
  • rose.athens
Emmanuel P.
