IK Multimedia iLoud Micro Monitor
m1ts0s
News poster
iLoud Micro Monitor - the smallest studio reference monitor in the world
iLoud Micro Monitor comes with two bi-amplified speakers that deliver an expansive stereo image, and ultra-accurate true linear frequency response, superior bass and plenty of power in a truly portable package. iLoud Micro Monitor is able to deliver stunningly clear and accurate audio thanks to its impressive technical specifications and smart design. Its two speakers are powered by four ultra-efficient class D power amplifiers that push a combined 50 W RMS of power. Each speaker sports a ¾” silk dome tweeter, a 3” paper cone performance woofer and a large flaring front-firing bass reflex port. Its sound is characterized by pleasing high frequencies, an exceptionally “open” midrange and a solid, controlled low end.
iLoud Micro Monitor provides a flat and linear speaker response in any listening environment. It’s able to do this thanks to its onboard 56-bit digital signal processor (DSP). This DSP handles the frequency and phase response of the monitor and also manages the dynamic range so that the drivers are always controlled. It also acts as a digital crossover allows for invisibly smooth transitions between the drivers themselves. This DSP can be adjusted to suit different listening environments thanks to three EQ switches: One for treble, one for bass and a “DESKTOP” toggle that lets users optimize iLoud Micro Monitor for use in either a free field or desktop setup. iLoud Micro Monitor can also be physically positioned at two angles of inclination.
iLoud Micro Monitor can also be used with a variety of audio input options. It accepts both RCA and 1/8" wired connections and can also be paired for Bluetooth streaming with all Bluetooth audio streaming-enabled device. With its portability and comprehensive input options, iLoud Micro Monitor is able to provide ultra-linear sound no matter whether they’re mixing in a small makeshift recording space, mastering in a hotel room, producing in a larger studio or just listening at home.
Features
  • Two bi-amped studio reference monitors for critical audio production
  • On-board 56-bit DSP for linear frequency response
  • Four high performance ultra-efficient class D power amps
  • 50W RMS total power
  • Phase accurate – perfect stereo imaging
  • Superior bass response
  • 45Hz bass extension
  • High and Low frequency level adjustment
  • DESKTOP switch for accurate response correction when placed on desktops
  • Comprehensive audio input: Bluetooth streaming, RCA, 1/8”
  • Thermoplastic enclosure designed to reduce internal resonance
  • Status/peak LED
Pricing and availability
iLoud Micro Monitor will be available early Q2 2016 from music and electronics retailers worldwide, and from the IK online store, for only $/€299.99 per pair (excluding taxes).
http://www.ikmultimedia.com/products/iloudmm/
DimAster
