• Built-in variable electronic crossover with selectable slope rate.
• Dynamic Bass Optimization (DBO) - This provides variable filtering with adjustable "Q" below 100Hz, far beyond conventional "Bass Q" circuits, by allowing the low-frequency output to be optimized for specific subwoofer applications. Frequencies below an enclosure's tunign frequency can be attenuated, preventing damage to the subwoofer and allowing the amplifier's power to be better utilized.
• Variable phase control
• Full-range preamp outputs - In the event that multiple amplifiers are used in an application, this feature allows for streamlined system hookup. No high-loss Y-adapters or splitteres needed.
• High Effective Damping Factor -The A6000GTi has a high Effective Damping Factor. The result is better subwoofer control and lower distortion.
Power Output: 2600 Watts RMS x 2 channels at 4 ohms
and ≤ 1%THD+N
8110 Watts RMS x 1 channel at 4 ohms,
14.4V supply and ≤ 1%THD+N
7400 Watts RMS x 1 channel at 1 ohm,
Signal-to-Noise Ratio: 65 dBA (reference 1 Watt into 4 ohms)
Dynamic Power: 6854 Watts at 4 ohms
Effective Damping Factor: 6.39 at 4 ohms
Frequency Response: 10Hz to 270Hz (-3dB)
Maximum Input Signal: 8.5V
Maximum Sensitivity: 250mV
Output Regulation: .2 db at 4 ohms
Dimensions (H x W x D): 6-1/2" x 29-3/8" x 23"
MSRP U.S. $: $6000.00
