JohnBlue Tube TL66 mono block
ΠΩΛΟΥΝΤΑΙ ΠΑΚΕΤΟ
JohnBlue TL66 Mono-Block
TECHNICAL SPECIFICATIONS:
COLOR: BLACK
Type: Monophonic vacuum tube amplifier
MAX OUTPUT POWER: 6W X 2
FREQUENCY RESPONSE: 20-20KHz ( ±1.5dB)
OUTPUT IMPEDANCE: 8 Ω
POWER SUPPLY: AC100~120V/50~60Hz / AC220~240V/50~60Hz
Distortion: 1%
Signal To Noise Ratio: 85dB
Input Sensitivity: 450mV
Input Impedance: 100K ohm
Output Impedance: 8 Ohms
Dimensions: 10.25 x 5.75 x 5.25 (LxWxH in inches)
WEIGHT: 13 kg
THE TUBE USED: OTK 6L6 x 2, Sylvania 6AU6 x 2
Tubes used are NOS OTK 6L6 and US made 6AU6 and 6L6 tubes are
DIRECTLY interchangeable with:KT88,EL34,6L6,KT77,6550
Επίσης Ηχεία mod. AMBIENCE by LOTH-X
Full range horn speakers
Sensitivity 97db .
Full range single driver backloaded horn speaker .
Τιμή : JohnBlue 2000 euro
Τιμή : Ηχεία AMBIENCE 800 euro
Γιάννης τηλ. 6974826650
roberto_portale
