Jones Audio
vlasis
Φωτογράφος!
http://www.jones-audio.com/specifications.html
Προ και μονομπλοκια τελικοι....φρεσκα μοντελακια......
Preamp 18000 $
Canada's Bryston displayed the BDP-1 digital music player (top) that's priced at $2150. The BDP-1 can decode any FLAC, WAV, or AIFF file with resolutions up to 24/192 and pass that digital signal along bit-perfect to a DAC such as Bryston's own BDA-1 (below). Bryston has stated that consumers should think of the BDP-1 as a 21st-century CD player. We'd rather think of it as the current successor to the CD player. [www.bryston.com]
The Jones Audio PA-M300 mono power amplifier ($24,000 per pair)
Specifications
Power: 300 watts into 8 ohms
580 watts into 4 ohms
Transformer: Ultra-low noise, shielded 1000 VA
Power Consumption: 775 watts
Power Requirements: 120 volts. 50/60 Hz
Class of Operation: A/AB
Frequency Response: 10hz-200Khz
(+0,-1db)
Thd+N: < 0.003 typical
SNR: -119 db (A-weighted)
IMD: < 0.003
Dimensions: 8.2" (H) x 16.2" (W) x 16.3" (D)
Weight: 80 lbs.
ΑΠΟΣΤΟΛΟΣ ΣΕΛΒΗΣ
